2.3L reliability
Timsvtgen1
Tim
Easton PA
2022 Audi Q3
Unfortunately, from what I understand- catch cans will void your powertrain portion of your warranty.
buildbigboats
Gordon
Chicago
2019 Subaru Forester
It’s because the 2.7 has a combination port and Direct injection, so that the ā€œ Carbon’d upā€ valves get washed off by gasoline.
But to get that additional port injection they have added twice the number of injectors, another lower pressure pump, more lines, hoses, connections etc. I understand the rational behind it but seems like more stuff to leak, replace, monitor maintain. An additional level of additional complexity...a bandaid. I'm going to take my chances with the 2.3. Have to anyway because I want the manual!
kodiakisland
Arkansas
siddious33
Charlotte, NC
2011 Jeep Grand Cherokee; 2016 Dodge Challenger Hellcat
I am wondering about this same thing, and I keep going back and forth. I think the 2.7 v6 is a better design, but to an earlier point, there is not a lot of difference in displacement here. You're either going with a single turbo, fairly large displacement 4-cylinder, or you're going with a twin turbo, fairly small displacement 6-cylinder.
I don't think either will be "fast" in the Bronco and for my purposes I'm looking at the manual Badlands, which means I'd have the 4.7 gears in the back too, so I'm sure it would feel fine.
At the same time, I'm coming from a Hellcat Challenger with 707 HP, so no matter what, either of these is going to feel deathly slow to me.
Staticclism
Moving back to MT!
230k mile 1996 Explorer XLT
Full disclaimer: I don't have any direct experience with the Ford 2.3.
That said, the amount of use and abuse I put the 1.8T turbo four I had in my '98 Audi A4 through was obscene; I drove that car to places most people wouldn't take their 4Runners (high mountain Forest Service roads that hadn't been maintained in well over two decades, 23" of freshly fallen snow). Eventually ended up going full send with upgrades (4:1 center differential, GT28RS big turbo setup, higher flow injectors and upgraded coil packs, full turbo back exhaust and custom tune) with a stock head / internals and even pushing out double its rated factory horsepower rating (and more than double torque numbers) the only real weak link was motor mounts which I had to replace after 40k miles running the fully modified setup. The engine ran flawlessly until a roommate of mine totaled the car - I got the car with 86k miles on the odometer, and it was totaled with just over 160k on the clock in three years.
I have little to no concern that the 2.3 will be both more than adequate and pretty robust. Just looking at power numbers the output of the 2.3 is similar to the older V8s Broncos could be had with while returning better fuel economy; at this point - in my opinion - the "hurr durr I gotta have a V8" is essentially just a cognitive bias / a talking point. I definitely want the manual, so I'm hoping that the rumors of them offering the Hybrid Bronco with a manual come to fruition.
kodiakisland
Arkansas
Timsvtgen1
Tim
Easton PA
2022 Audi Q3
No it won't.
If Ford decides to deem your catch can as the culprit for your engine issue/failure( whether you think it is or not) , they won’t cover it. You can buy THESE , but the disclaimer also tells you its not to pass emissions and or be driven on public roads/ for racing use only. I don’t agree with any of that... its just simple catch can, but... the fact is, they will deny coverage based on a catch can IF they deem the catch can the cause. Maybe one can get lucky and a dealer will glance over it intentionally, but its a liability if you are interested in your powertrain warranty. The internet’s are full of this discussion.
Staticclism
Moving back to MT!
Should look like it belongs there.
Wow you weren't kidding. Poking around the instructions PDF on the part page the install guide pictures show it fairly well, you'd never even know it was there unless you knew beforehand.
BattleBornBronco
Jon
Las Vegas
2021 Bronco Badlands
from what little i know about these engines the 2.7 has something that reduces carbon buildup that the 2.3 doesnt
I am concerned about carbon buildup too, but I'm hoping it's mitigated. Not sure how accurate this is, but the Ranger 2.3 might have a separator assy built in. https://www.ranger5g.com/forum/threads/oil-separator-vs-catch-can.8714/#post-158698
Still, people have posted pictures of oil pooling in their aftermarket catch cans which means we might be better off than Mustang 2.3s, but there is still some making it through even on the Ranger 2.3.
kodiakisland
Arkansas
Yes, if it affects a part or system, then it can be denied. It will not void your whole powertrain warranty.
siddious33
Charlotte, NC
coolrain
Marcus
NJ - Bergen County
2000 Ford Ranger, 2014 Camaro 1LE
Ford Bronco 2.3L reliability 1597347015959
Ford Bronco 2.3L reliability 1597347427142
OK I'm done.... knew I would see this topic. BIG debate on most sport car forums. The one thing I know is the one I have on my Camaro has oil in it every time I do a change. This oil would be going in otherwise ..... drum role... now the debate if the car burns it yada, yada yada.
Makes me feel better...... OUT
Ford Bronco 2.3L reliability 1597347639488
kodiakisland
Arkansas
Also says right there on their page that it's intended for off street/competitive use only and likely makes your emissions illegal. :)
I promise not to drive it in CA.
Timsvtgen1
Tim
Easton PA
2022 Audi Q3
[/QUOTE
Pardon my semantics, but I never said whole. The dealer knows their way around the Magnuson Moss Act and blame you accordingly.
