2022 2.3L Getting Sluggish
Do we know whether these engines are a type that "learn" driver behavior? I thought I remembered reading somewhere that some engines start anticipating what you're going to ask for when you do certain things, and tune themselves accordingly to e.g. reduce emissions or fuel consumption. Since you're driving stick, it obviously isn't the transmission doing anticipatory shifting and power modulation, but perhaps it's gating the throttle somewhat for some other reason. You could also try Baja mode with some manual adjustments to off-road settings.
I find in mine that in "standard" mode, I need to goose the throttle quite a bit when starting out, or it looses too much power getting going as the clutch comes out.
The engines have a bit of memory for octane/knock - but that doesnt really affect driving
The transmission has adaptive learning which can adjust shift points over time; that is significant enough that I can notice if someone else takes it for a drive to the store and back that it has adjusted.
If you do use a fuel additive - I recommend a bottle of Chevron Techron....I will dump one into the tank at oil change interval.
Won’t do any good on the older Direct Injection 2.3 - fuel additives never touch the valves. If you want to try a cleaning product it has to be an aerosol through the air intake while running, or take it apart and blast it
Area51BS
Ron
Badlands non SAS 4dr 2.3
Can’t stand this feature. Soon after leaving the lot and get some miles they never feel the same.
fuesting
fuesting
T H E S T E E L C I T Y
2022 Ford Bronco Badlands
I'm a big NGK plug fan, and 70k on any turbo engine is probably overdue for plugs.
I don't have a 2.3 in front of me, but looking at this pic I found, the hose on the intake manifold at cylinder 4 looks like it can be removed.
Look inside that hole with an endoscope/inspection camera (cheap on Amazon and insanely useful) and you can probably see the intake valves.
Thanks much man. I have a bore scope. That looks easy enough. Going to replace the plugs regardless. I'm the kind of person that doesn't mind taking something on with the right guidance. Thanks
Smocaine
DFW, TX
Cervelo Caledonia
If you don't like how your automatic transmission shifts, you could always do it yourself 😉
I would have said air filter if you didn't do it already. Maybe it's just a placebo but I always feel like I have a bit more jam after getting rid of a well-used filter.
ScottyC
Rome NY
2022 Bronco 4 door
Something is better than nothing
contented
Karl
Central Fl
BMW M2 Competition
This is what they look like at about 40k miles. New plugs changed the sound and the idle for the better, ie quieter and smoother.
Ford Bronco 2022 2.3L Getting Sluggish IMG_0792
userdude
Denton, TX
2023 2dr Badsquatch
Those would be the next best option.
Probably the best plug that’s one step colder. Just not really sure it’s needed for a non-tuned engine, but that’s up to you. It won’t hurt anything.
I have these in my 2.7
Edit: Nevermind, I have the LTR7BHX, which are one step colder.
Is there any justification for colder plugs if I'm running the milder FP tune on the 2.3?
It won’t hurt. But no specific advantage really. I got a set from Lethal when they were running a sale and got two sets for like $50
brkdncr
Southern California
Toyota 86
You’re right in that Techron is less effective on DI-only engines, but it also helps maintain the fuel delivery system. Primarily protecting against the long term effects of ethanol.
Ducati1098
Nah the stock ones will be more than adequate.
IMO you really only need to go one step colder if you have a custom tune and start pushing things quite a bit harder.
userdude
Denton, TX
2023 2dr Badsquatch
Well, if I'm pushing it seems like spark plugs might not matter... 🤔 :LOL:
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
I have not done either. I feel like the plugs need to get done either way. What would you recommend on the turbo? I'm unsure how to diagnose properly. I will say my main complaint is low end torque, so maybe not the turbo?
I will be changing my plugs every 50,000 miles, as I do in my other gasoline vehicles. They'll function to 100,000, but not at peak from 50,000.
fuesting
fuesting
Finally changed mine. Maybe a little improvement in performance or maybe its in my head. I was hoping for more. Will investigate carbon build up on valves. Here are the plugs:
Ford Bronco 2022 2.3L Getting Sluggish IMG_0561
Ford Bronco 2022 2.3L Getting Sluggish IMG_0559
Ford Bronco 2022 2.3L Getting Sluggish IMG_0560
