Tex
Cliff
San Angelo
jorgem31
Jorge
Tampa
rsmag9
Ford's
I’ve never used forscan before but want to change one of the cigarette outlets to always on for when I flat tow (supplemental braking system). Can anyone give me the steps to do it? Thanks!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
It’s limited to 18 hrs now.
Tex
Cliff
San Angelo
That would work for me, can you give me the details on what to do? Thanks!
Check #13 on the spreadsheet:
Also this thread might be helpful:
https://www.bronco6g.com/forum/threads/rear-12-volt-port-timout.29712/
Personally I wouldn't bother reprogramming, I would simply trace the wire back up to where it gets power (probably under the hood somewhere) and re-route it directly to the battery. If you wanted to be fancy, use a three position switch inline so you could choose whether you wanted to power it straight from the battery for peace of mind when towing, or powered by the circuit so it will have a timeout for battery protection when you're not towing. Just run the original wire to one pole of the switch and the battery wire to the other, then connect the wire going to the power point to the center. Flip it one way and you're on battery power, flip it the other and you're back to OEM operation, make sure you label it correctly LOL
H0pelessOpus
2015 Xterra PRO-4x
All - I'm working off this thread started by @MattInNash. I'd like to enable ACC with stop & go.
Here's the list of changes I've gathered so far.
ModuleDescriptionSettingValue
PCMPowertrain Control ModuleRelearn Central Programming-
BCMBody Control ModuleAdaptive Cruise ControlAdaptive Cruise Control, Stop and Go
APIMAccessory Protocol Interface ModuleIntelligent Adaptive CruiseEnabled
IPCInstrument Panel Control ModuleIntelligent Adaptive CruiseEnabled
IPMaImage Processing Module AAdaptive Cruise ControlEnabled
ABS???
I need help deciphering what to edit in the ABS module. Based on the Tremor/Raptor F-150 ABS module breakdown I believe I need to select one of the options in red below.
However I don't know what CMbB (CMB) and HDC (HDC) mean. Appreciate any insight. Cheers!
Ford Bronco 2021+ Bronco ForScan Thread 1686529308003
mpeugeot
ABS???
HDC is hill descent control
CMbB is collision mitigation by braking
Just saying... LOL. ;)
H0pelessOpus
2015 Xterra PRO-4x
23CarbonizedBadSas
Jacob
Well, if you ever find yourself in Texas, I'll help you out no charge.
Tex, Are you still offering to help 'newbs' with ForScan programming? I'm in the DFW metro and could really use a tutorial on all of this.
mpeugeot
I am not far from Tex, and when it comes to FORSCAN, I would help you out no charge as well.
pizzy
larry
Pa
2023 bronco base
Newbie help needed! After swapping out my standard headlights for the signature headlights, I am getting 2 DTC error codes in Forscan. The first is B14E5:55-0A and B14E7:55-0A. These are for the left and right headlights and are basically stating that I have not configured these modules. Can someone who has the signature lighting tell me what their stock configuration is so that I can change mine and get rid of the error codes? Otherwise, the lights themselves do seem to be working properly with the exception of the ring leds not turning on when opening the door when the car is off ....it is just that the error codes keep popping up in Forscan. Community assistance would be greatly appreciated!
Ford Bronco 2021+ Bronco ForScan Thread frscan
Phox
Daniel
I cannot get my pscm to run self test in forscan. All condition being met, vehicle not moving and key in on engine off position. Have tried multiple times and keep getting messages that self test failed to start. Any idea why it would do this?
SlowPoke
Tom
Connecticut USA
What?
This has to be possible, we’ve seen it for almost a year now but still no one has cracked the code.
This is the grail.
I want to do this to mine, I posted a question about it a few months ago... Still no solution? I'm pretty sure I saw a bronco on the road the other day with it done... I just went out to try mine...
Successes:
No Double Honk
Badlands now with Sport Mode
Orange bars on all headlight modes (not with rings off though)
Bambi mode (high beams and fogs together)
Failures:
Cameras at speed
[[[EDIT]]] On closer inspection I found that having the Orange bars on - set in forscan to anything other than "turn only" Results in having no front turn signals. They don't flash... Will keep this updated if I find a solution.
