Tex
Cliff
San Angelo
Tex just got scared.
Not scared, I have mine already. I was surprised to see that they weren't there, that's news to me. Sucks. Good luck with your original post stuff.
AGM Everglades
Everglades
Los Angeles
5 early broncos, AGM Everglades
Everglades
Has anyone successfully added 360cam to a mid package? The Everglades has the 12” screen but it’s a mid package. Assuming if I bought all the hard parts (front cam, side mirrors and harnesses) and fab’d a front camera mount I’d need to add the programming in Forscan?
BT!
Bud
tallahassee
bronco
Has anyone figured out a way to use FORSCAN to make the bronco start is sport mode ?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
RE: adding rear defrost to pre-prep kit 2021.
Bummer. The Forscan beta seemed to have worked in that I was able to write to HVAC and enable Rear Defrost…but, still doesn’t appear to be heating up the rear defrost grid.
Next steps:
- FDRS?
- missing something in Forscan (going to dig into F150 spreadheet)
- replace HVAC Control ($$$)
Seems like a lot to go through for rear defrost - but, at this point I want to crack the code.
Just to have it all in one place. This is what I’ve done so far - to no avail:
- Installed wire assembly (M2DZ-15A657-A)
- Enabled ‘Rear Defrost’ in APIM and HVAC
- Enabled ‘Heated Mirror Output Relay’ in HVAC
- Changed APMI - 7D0-02-01 xxxx xxxA xxFE
Still nothing.
BT!
Bud
tallahassee
bronco
after reprogramming the tire size everything worked great for a couple of days then I get and error message on TPMS failure any ideas (tire pressure looks fine and speedo is not correct)
Figured it out habe to buy a reset tool off amaxon for $30.
illverado
Cory
700whp stick shift 2000 silverado 23 basesquatch 2dr 7mt
Can any of you geniuses help me disable ASS on my 2023? They recommended abs but that is an as built and I don’t know what to change in there since it’s all scary numbers and letters 😬
Ford Bronco 2021+ Bronco ForScan Thread 3DEBA24A-67A2-4B9C-AC07-4E7A44E16708
BT!
Bud
tallahassee
bronco
There is a you tube video you have to disable in 2 modules. I did mine and works perfect it even somehow quit giving me a message magically
BT!
Bud
tallahassee
bronco
Bump... would be cool if someone made a $100 dongle like for the stop start thing/
Tex
Cliff
San Angelo
BT!
Bud
tallahassee
bronco
Yea I have the dongle already. I meant a dongle that would leave the vehicle in sport mode at start up. The 4 banger is fine in sport but anemic in other settings
4DTech makes one too, and they make a few other cool modules for other things.
They make modules that address about 95% of the posts in this thread.
https://www.4dtech.com/products/ford/bronco/2021/
Tex
Cliff
San Angelo
Oh, must have missed that part. That'd be a nice feature to have for sure.
SillyPosition
Silly
Israel
None
Anyone tried the BT OBDLink MX with forscan windows, does it work well?
I already have it and it seems odd to buy the simpler wired model as well.
BCHBRNC22
Virginia Beach
2022 Ford Bronco
Any Forscan experts here in the VA Beach area? Would be happy to pay for your time to make some changes. Thanks! Mike
