which hood prop?
Valhalla
Valhalla
Chattanooga Tn
Okay, makes sense. As I read this I wondered why. Then I thought about how old hoods did a coil to lift . I assume factories left that for costs and weight savings. Once I guessed that I considered the tensile strength of tho hood they make. I now wonder if the pivot point where a non stock prop attaches on a long enough time line, will start to damage the hood.
Just how my thought process went. I may be off.
Valhalla
Valhalla
Chattanooga Tn
I like the raise the hood higher. One thing I liked about all my HEEPs was the ability to open the hood back to the point it restedon the windshield.
AB8DT
Ron
Cedar Springs, Michigan
www.qrz.com
23 Bronco 4 Door HLE / 2024 F150 Crewcab
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
That's a reasonable consideration, but so far after a lot of use, I haven't noticed any signs of strain on the attachment points or hood in general.
Related to that though, it seems to me the struts that attach closer to the hood pivot point might cause more stress due to the leverage and greater cylinder force needed, so review that aspect if concerned.
Also I did not remove the stock hood prop. In case of some high wind situation, it might be better to use that. Otherwise the hood struts I got are convenient, more out of the way and raise the hood higher than the stock prop. Struts are not required but I appreciate them every time I have to raise/close the hood.
That’s another aspect of the MRT hood struts that I didn’t mention in my post earlier. That if you’re using MRT hood struts and you have your hood open on a windy day watch how the top of the hood bounces continually up and down and then look at the hood at the fulcrum point where the hinge mounts to the hood and you can see it flexing. Eventually that will likely be a failure point.
Redline Tuning
F-150
https://www.redlinetuning.com/SearchResults.asp?Search=2021++Bronco
Redline Tuning is pleased to be a sponsor on the Bronco6G forum and want to showcase our 100% Bolt-In MADE IN THE USA Hood QuickLIFT system for the Bronco. Our system is the ORIGINAL Bolt-In system for the Bronco and installs in less than 10 minutes with no modification required to your vehicle or for you to un-bolt you hood to mount any brackets. We offer two different lift heights for the Bronco. Our standard QuickLIFT system raises your hood to the same height as the factory Prop Rod and our Max Lift system raises the hood 8 inches higher for maximum access to the engine compartment. Both systems are available in PLUS, Carbon and ELITE versions as shown below.
Ford Bronco which hood prop? bronco-maxlift-jpg-jpg-jpg-jpg-jpg-jpg
Ford Bronco which hood prop? bronco-quicklift-plus-jpg-jpg-jpg-jpg-jpg-jpg
Ford Bronco which hood prop? bronco-maxlift-plus-jpg-jpg-jpg-jpg-jpg-jpg
QuickLIFT PLUS features:
* All black powder-coated mounting hardware
* Black e-coated gas springs
* 4 year warranty
available directly from our website here:
QuickLIFT (same height as stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11040-02.htm
MaxLift (8" higher than stock)
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-PLUS-p/21-11039-02.htm
Ford Bronco which hood prop? bronco-maxlift-carbon-jpg-jpg-jpg-jpg-jpg-jpg
QuickLIFT CARBON features:
* Black e-coated gas springs with real carbon fiber sleeves
* 4 year warranty
To add the Carbon option check the box show below on our website:
Ford Bronco which hood prop? carbon-jpg-jpg-jpg-jpg-jpg-jpg
Ford Bronco which hood prop? bronco-maxlift-elite-jpg-jpg-jpg-jpg-jpg-jpg
QuickLIFT ELITE features:
* 316L Stainless Steel gas springs
* 5 year warranty
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11040-03.htm
https://www.redlinetuning.com/2021-Ford-Bronco-Hood-QuickLIFT-ELITE-p/21-11039-03.htm
Free shipping in the CON. U.S. on all Bronco systems using coupon code "Bronco6G" at checkout.
You can watch the video below to see how easy our installation is, the only tool required is a 13mm socket:
Here is a video of the different gas spring finishes and the system in action:
Redline Tuning has been developing our Hood QuickLIFT systems for over 20 years and have applications for over 350 unique vehicles, check out our website for your vehicle application.
Please contact us for any questions.
