Hood struts on a Aftermarket Hood !!!
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Since I switched Hoods on my Bronco, I have been unable to use my Redline Tuning Hood struts, because there were no mounting holes in the AFC Ram Air hood. I was going to build a plate and fabricate my own, but then @Redline Tuning came to the rescue. They have a kit that will let you use their struts on a After Market Hood.
So, got the kit, followed the instructions, and it was a breeze, and works very well. Lifts the hood easy, and holds it tight at the top, and just as easy to close. Very happy with the outcome and no more Prop Rod needed.
Thanks @Redline Tuning !!!
Here's some pics.....
Ford Bronco Hood struts on a Aftermarket Hood !!! image0 (34)
Ford Bronco Hood struts on a Aftermarket Hood !!! image1 (26)
Ford Bronco Hood struts on a Aftermarket Hood !!! image2 (22)
Ford Bronco Hood struts on a Aftermarket Hood !!! image3 (13)
Ford Bronco Hood struts on a Aftermarket Hood !!! image4 (4)
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
Are your fender flares and grill LineX sprayed?
Yes, as well as my Hardtop, and rear Bumper. Will do the same on my Rock Sliders and Front Bumper when I get them completed.
Redline Tuning
F-150
For those who already have our Hood QuickLIFT system for their stock hood and switch to an aftermarket hood, we have the retrofit kit available here:
https://www.redlinetuning.com/product-p/21-11042-05.htm
Ford Bronco Hood struts on a Aftermarket Hood !!! Bronco Aftermarket
If you don't have anything, this is our system designed specifically for aftermarket hoods:
https://www.redlinetuning.com/2021-Ford-Bronco-Aftermarket-Hood-QuickLIFT-PLUS-p/21-11042-02.htm
Free shipping in the CON. U.S. on all Bronco Hood QuickLIFT systems using coupon code "Bronco6G" at checkout.
Tdifonzo
Thomas
Audi S3
How does the LineX hardtop compare as far as wind noise to the original?
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
It's a little quieter than before. Never had a problem with wind noise though, until my TSB Seal was replaced. Going in again to get it done again.....
adamruiz2001
SoCal
Ford SVT Lightning
Good info man...
Do you have pics of your hard top? I bet it looks sharp...
Shoot, show us the bumper too :)
Bad_Bronco
Bad_Bronco
Peter
Port Coquitlam, BC
