What offset?
Bake1550
Harrisburg Illinois
2019 Mustang GT. 2020 F150 limited 2001 Porsche
I am getting ready to order a new set of wheels and tires. I'm sure this has been addressed and answered. But what offset would be best for the wheel and tire to be flush or slightly inside the fender flare? I don't want it outside the flair. Also, I'm considering using a 10" rim.
2023 Bronco Wildtrak. Sasquatch package. Stock height currently
Please and thank you for your information
Ford Bronco What offset? IMG_1742
Ford Bronco What offset? IMG_1743
RagnarKon
Ford Bronco, Escape, Focus
Depends on the tire size ultimately.
For the typical 8.5" rim you're looking at an offset between 0 and +30. At 0 offset, the wheel itself will be roughly in-line or slightly in (varies on the wheel design) from the fender, but the tire itself may poke beyond the fender depending on the tire size.
WarthogJr
'21 Bronco Black Diamond
Oldhippie
Barry
Santa Cruz, Calif.
9” rim will push them out 1/4”…I’m gonna say +18-+12…depending n actual tires ya use…
87-Z28
Andy
BMW
I would think more about keeping a good scrub radius. Then worry about the fender flares.
HoosierDaddy
__ Eric
NW. Indiana
https://tiresize.com/wheel-offset-calculator/
While learning about offset, should you decide to educate yourself,
....... you'll discover that the calculator I linked to above doesn't even ask for the wheel width because when using the center line as the point of reference, wheel width has very little effect on where the tire will ride within the wheel well area.
The tire beads may move in or out a bit, but the tire tread will still be aligned to the center of the wheel.
Method 703
17 x 8.5
+30mm
35 x 11.5 - 17
standard flares
Ford Bronco What offset? 1719200982921-1k
Flying Skunks
Donnie
23 Badlands Sasquash
This is on a Badlands with SAS , so larger fenders .
I am running 37x12.5x17 Kenda Klevers on a Zero offset 8.5" wheel
Ford Bronco What offset? 20240522_181915
Ford Bronco What offset? 20240522_181907
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
Wow, nice to see someone else who understands suspension geometry. It’s a rarity!
87-Z28
Andy
BMW
Kingpin axis might be around 60-70 degrees in camber plane wrt ground surface. Estimated from base non SAS with 30s on 55mm offset to SAS with 34.4s on 30mm offset.
Tan^-1 [ 0.5(34.4-30) / (25/25.4) ]
So about a 10-12 mm laterally outward location for every 1” increased tire radius. To keep close to OEM scrub radius, assuming SAS on 35s with 30 mm offset, then maybe (rough math); 15-20 mm offset for 37s, and 0-5 mm for 39-40s.
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
8.5 with +12 for Squatch fenders... Zero has a small amount of poke. You can also do +25 if you want them to stay slightly under the Squatch fender.
