Tried a USB CD drive, doesn't work ;)
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Playing CDs has come up a few times on here, and I always wondered if a USB CD Drive could be plugged into the USB and work, Kind of like plugging in an MP3 player or even just a USB thumb drive with music on it. Well, I just got a DVD/CD RW drive because my oldest is going into music theater camp tomorrow and they sent some songs she needs to be familiar with. My kids are 8 and 5, and we don't want them having devices and too many distractions, so they have CD players in their rooms and CDs to listen to, and I got the drive to burn a CD with the songs my 8yo needs to listen to instead of giving her a device.
So, since I now have a USB CD drive again, I thought I'd plug it in to the Bronco and see what happens. And nothing - I got a message that the USB device was not responding. Just in case anyone was wondering ;)
Oh, and it didn't work in my RAM either ;)
helifino16
Ron
Mount Sinai, NY (Long Island)
Well, it makes sense to at least try it since all the connection points are there. Put the songs as MP3’s on a flash drive and you’ll never listen to anything else. Unlimited songs, no loss of signal, no commercials, skip whatever you’re not in the mood for. It’s worth the effort.
GnormalGnome
ee
PNW
2025 Ford Bronco
A standard usb cd-r/rw drive is not really compatible with vehicles, as you've discovered. They are designed for pc data transfer. Even if it worked, you would find that even mild bumps on the road would disrupt the players ability to read the disc, causing skips or track resets.
There are mobile players designed specifically for use in vehicles. Cheap ones can be gotten for ~$50, but they compress the data transfer even more, so the music is no longer 'cd quality'.
And speaking of quality, mp3 is one of the worst formats ever created if you care about music. 🎶
Jossman 2026
Monument,CO
2022 Bronco,2013 F150,2011 Mustang +2006 HD
I have a 2022WT with LUX.The 2 USB ports on top of the dash are for charging only-need to use The USB ports in the area in front of the gear shifter below the front panel as they work for accessories .Mine from Amazon + basic plug in + follow a few directions on the screen.Works great for an old guy with lots of CD's + very little Tech Savvy.Just may need a USB extension cable depending on where you want the player to sit.Only drawback is you have to push eject button on player as I have found no other way to eject CD.No problems with skipping while driving but have not used on any hard core trails.Any time it is connected + you want to listen to radio 0r something else you just use source on audio screen.
Ford Bronco Tried a USB CD drive, doesn't work ;) 29067225_2023498157690642_7458119832290983936_n
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Wait you got it to work playing an external CD drive in the lower USB port? Or did u buy something off of amazon. I’m confused
Jossman 2026
Monument,CO
Plugged the external CD drive into the Data Port[inside the cubby hole in front of the gear shift followed on screen prompts + it works fine!!!
cbrenthus
Western PA
Link to CD player?
And, while I knew it wouldn't work, I just thought I'd try since I now have a CD drive ;)
Also, while I usually listen to Pandora in the RAM and Bronco, I'm keeping my Trans Am period correct and it has a CD player. And there is something really refreshing about loading a CD, listening to 1 album at a time, without my phone connected to the sound system to make a noise every 27 seconds because of a text or alert. ;)
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I still can't get my 8 tracks to work either. So frustrating!
Jossman 2026
Monument,CO
As far as a link go to Amazon + choose the 1 you like.When I got mine a few years ago it was in the $60 range.Looks very similar to what I use at home to add CD's to my i Tunes Library on my Mac.
5GENIDN
Joe
Idaho
I copied my CDs to a hard drive (lossless format).... Now I copy them from the hard drive to a thumb drive and plug in the thumb drive to the USB in the Bronco... I can now play one CD at a time or place it on shuffle. I put 50 to 100 CDs on the thumb drive at a time. It works really well. I can search by artist or any other filing system I set up on the thumb drive. I can make a folders for each genre and play randomly per genre if I want. It is handy....
Oh and I am old enough to have had the very first 8 tracks made for cars... By Lear Jet... Had it in my 1967 Firebird. Even had a Centrix 8 track recorder at home.... Used to record certain radio shows that I could play back.
8 track always seemed to be a bit of a misnomer because you had 4 tracks with two channels each. That was that big "click" you had as the head changed physical location to change tracks Four lights showing which "track" the head was set to.
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco, '25 GR86 w/Performance Pack
Love my little GR86, still plays iPod's. I see VB's have a single disc cd player
Next revision or next gen needs a cd player back in it
