USB thumb drive
Gypsyjon
Saint George Island Fl
2020 Roxor. 2015 Ram EcoDiesel
Due to the lack of a CD player I have loaded lots of tunes onto USB thumb drives. When I plug it in the system recognizes it and will begin to play. After a few tunes or about 15 to 20 munutes, it just stops playing, usually mid song. I believe I have formatted them correctly, and everything seems to work until it doesn't. What could be the problem?
Gypsyjon
Try formatting the drive in FAT32 with Windows rather than the default Win format.
Bellime
Keith
2022 Ford Bronco
Bellime
Keith
2022 Ford Bronco
Don’t call your Bronco fat, next thing it will need therapy
Adoptwithme
Oh
Honda Pilot
I don't know if this is it, but the next time it stops playing touch the USB drive and see how hot it is. I have one of those tiny little USB drives that barely stick out. Problem is they get super hot.
Initially I thought maybe it was the Ford USB port that was overheating. But I put a small extension cable in between and the heat stayed with the USB and not the plug.
And I have a name brand USB.
I have this issue, also. Sometimes the thumb drive gets too hot to touch-
da_jokker
Jeep Wrangler JKUR
Yeah..same thing happened to me..dang near burned my finger when touching the metal part. Got to the point where I was leaving it out and only plugging it in when I needed it.
That's what got me thinking so I tried a larger USB stick and it staid much cooler.. that's when I though about the short USB extension (just happened to have one).
Adoptwithme
Oh
Honda Pilot
I will try a larger usb. I also remove mine after use because it is just too hot to leave in 😬. Thank you for the recommendation!
mhtucker78
Matthew
VA
2023 OBX Bronco
I tried using my Zune..."device isn't supported" Zune is dead, long live Zune!
