Bluetooth doesn't work,. Can't even turn it on.
JeepDefector
Mass
Lexus
Got my 2021 BigB bronco on 1/25. Bt wouldn't connect. Took it to dealer who reset the system and it worked for less than 24hrs and dead again. Can't even toggle the bt on. Anybody have this issue? Any suggestions?
JediMcMuffin
Tommy
2021 Bronco Badlands
Sounds like a bad module. You can try disconnecting your negative battery terminal for a few minutes, but likely a dealer replace/repair required.
SamG
Sam
Detroit Area
sas
Do you have the lux package? with the giant screen and such?
JeepDefector
JeepDefector
Mass
Lexus
Thanks...probably good I know nothing about vehicles...keep me from getting into a mess trying to figure out what you are talking about....:) I am awaiting another reply from the dealer...Kind of frustrated 3 days in the thing is already causing me issues. Hopefully an easy fix.
palley6
Orlando, FL
Are you using Wireless Android Auto/CarPlay? If so you'll have issues while running either simultaneously
JeepDefector
JeepDefector
Mass
Lexus
HHmm....Haven't actually run much of anything because BT won't stay connected. In theory, shouldn't Android auto work as part of the BT connection? I don't know, whole systems seems buggy to me...and Maybe I just need new hardware unit.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
Is your phone set to automatically reconnect to Bluetooth sources? Can you turn the truck on and then connect using the Bluetooth screen on your phone?
Also this doesn't help your situation, but you are correct. Android auto uses Bluetooth as part of the connection. When everything is working correctly on Android auto, any audio played on the phone comes through the bronco. It will switch seamlessly between Bluetooth youtube audio and back to pandora on Android auto. Or whatever combo of sounds you send to the truck.
A tip for people. If you are listening to pandora on the Bronco and a Bluetooth audio source, such as YouTube, takes over, just press play on the screen or steering wheel and the music will override the other audio.
I don't know if this works in Car Play
JeepDefector
JeepDefector
Mass
Lexus
Thanks. I actually can't even turn the BT toggle in the Settings to the "on" position. And the Service peeps at the dealer never called me back today...I smell trouble on this one...
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. Will you send us a message with your VIN and dealership info? I would like to look into your Bronco's Bluetooth issue on my end.
JeepDefector
JeepDefector
Mass
Lexus
Hi...Thank you very much. I just sent you a private message/conversation with VIN and dealer. I appreciate the help...
jclark
Jeanette
Mid-Michigan
I know this an old thread - but I just experienced the same and wondered what the fix was.
2023 BL lux - got in after having some work done and wouldn't connect to my phone. Went into settings and see BT is turned off. Won't turn on.
Rocky Rocks
Spectre_Bronco
Miami
Hi JC. Have same issue. BT won’t turn on. Did you fix yours?
