Tailgate Tables
Wanderexplore
Andrew
Boulder, co
Lancer gts
Doesn't look like anyone has a slide out cutting board or extension. Curious what the cons would be.
zedster
Bill
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
It's just those little plastic trim tabs that slide onto the edge of the tab holes (four small upper ones and two larger bottom ones). I dropped one of the large ones down inside the cavity.
Good call about removing that plastic grill. I didn't even think of that. Is it pretty easy to pop off?
That might rattle like crazy if you leave it too. Maybe try one of those skinny long grabber tools that you can pickup at a hardware store? It’ll take some fishing but likely not too difficult.
CyberVegas
Ali
Las Vegas
BRONCO
I co-sign in the jcr off-road table…I have about 20lbs of gear mounted to it and not the slightest rattle and best of all no drill install
zedster
Bill
Las Vegas
Badlux
Delaware
81 Scrambler , CJ-8
A rep from Tuffy did they will be releasing a lock box tailgate table. Extends out a few inches bit gives lockable storage. Not available yet that I have seen
Murraydog11
Rick
NJ
2021 2Dr Outer Banks, Jeep Cherokee
I went with the Ford table. I'm happy with it.
That Rock-Slide is pretty sweet though...
Ford Bronco Tailgate Tables 20220211_145657
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
DUSTYcazOREGON
Craig
2022 Bronco Black Diamond & 2025 Yukon Denali. 2023 Mercedes Adventure Wagon.
I chose the one from Rock-Slide Engineering, after looking around at all the ones available at the time I liked its features best. I liked that it has the most table surface area, has an upper shelf, and doesn't use cables so it has the highest weight capacity. You can even place a Blackstone grill on it. I also liked how it didn't replace or cover the factory plastic interior vent cover. It mounts with self-tapping screws, which some see as a negative. But I've had 4X4's for years and have overcome my fear of drills LOL.
I like that one too but the install looks like a b_ich. You need to remove the spare tire, tire mount....more to the install than the other brands. Old fart here.....I need easy.
Ksjrb03
Tx
F250
So they seem somewhat durable?
Oh ya they are high quality no complaints. But I didn’t shop around so I’m sure there are cheaper ones. I just ordered the table and bags in an accessory order using the Ford points.
