- Chris
- Nov 4, 2024
- 27
- 1,481
- 2,411
- Southern New Mexico
- 2016 Sequoia, 2012 Tundra, 2024 Sasquatched 2.3L 7M 4Door Bronco
- Big Bend
Nice summary.There are two main load issues when you put weight on the tailgate. The first is direct shear that translates to the hinges wanting to bend them and/or their mounting points. The second is the buckling that can occur on the face of the tailgate itself. The tailgate skin can easily buckle when the weight of the spare tire flexes up and down and when it does, the ability of the panel to carry the shear loads to the hinges drops significantly. Plates like the rough country or hammer built primarily help or counteract the buckling which is important. The plate is 10+ lbs so the actual shear the hinges must carry is higher but they are steel and much stronger than the panel they are bolted too. It really is a 3D load problem, not just a 2D shear problem. Most of the bent tailgates you see are buckling failures.
The best solution is both a better hinge and a stiffener plate against buckling. Above that, is a separate bumper mounting solution.
Just to verify, does anyone know fer sur if the FP reinforcement system:
https://www.bronco6g.com/forum/thre...or-broncos-here-at-lethal-performance.108707/
is an actual reinforcement plate? I ask because I can easily see some plates/systems really being for aesthetics, or additional mount points, etc. and not an actual reinforcement of the tailgate itself....maybe I'm too cynical about the aftermarket
EDIT: Will probably start with @Brian_B suggestion of tinkering with the alignment of the striker plate, but might reach for one of these reinforcement kit as well...
