Suspension install price?
Dtom417
Derek
Portland Maine
Infiniti g25x
I contacted my local 4x4 shop for an estimate to install 4 new Bilstein 6100 and to swap the springs over from the old Bilsteins . The price they gave was 1775.00 , this is just labor and not including the new shocks . Is this really high ? Or is it just me ?
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
A ballpark labor estimate is $250/per corner without upgrading TREs and UCAs. And that is for a fully assembled coilover. Disassembling your old shocks and using the springs requires additional labor.
Any install should include alignment and readjusting headlights.
Your estimate is on the high side presuming the UCAs and TREs aren't being upgraded.
Hey Buddy
Drew
2022 Ford Bronco Base Model 2-Door 2.3L 7-Speed
I paid $1200 to have my Badlands take-offs installed. It was around an 8 hour job & was done right!
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
OP, note y'all are in the same state.
Didn't notice that lol.
Yeap, had it done by lifetime in Gray. They're the only place I'll go if I'm paying to have work done.
Dover157
Ben
Moriarty NM
2022 Bronco Black Diamond
I will let you know in a couple weeks, mine is going in for surgery the day after Christmas to have Eibach pro truck 2.0 coil overs installed.
OCNORB1974
Dale
Missouri
2022 Maverick
I was quoted $1,050 labor to install Eicbach 2.0 coilovers, new UCAs, and an adjustable panhard bar. This also includes an alignment.
Muffin Top
TX
JK, MK, KK, TJ, DN
It seems like labor rates now are almost double what they were before the vid
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
I called a local 4x4 shop familiar with Bronco installs. For all 4 corners, I was quoted 6 hours at $185/hour + $150 for alignment. That's $1,260 Canadian pesos, so probably $1,000 USD tops.
PetePerkins
Pete
TN
2024 Black Diamond
Seems high to me, but I do my own.
Too high for sure! When I 1st got my Bronco I got a $1.3k estimate to install a 2" lift not including cost of lift. I ended up doing it myself. With proper tools it was actually easy and I walked away knowing that it was installed perfectly and bolts torqued to spec.
Silver-Bolt
Eureka, MT
Exactly how and why I started doing my own work years ago. I couldn't afford to ridiculous labor prices and I had seen why too much shoddy work. The old saying "if you want it done right, do it yourself" applies.
Dover157
Ben
Moriarty NM
Just had my local off road shop install Eibach pro truck stage 2 coil overs on all 4 corners. Total including parts and alignment was $2,890. Definitely could have done it myself cheaper but I don’t mind paying for the peace of mind of having it done by someone who knows suspension better than I do.
Ford Bronco Suspension install price? IMG_5266
