Steering Wheel Spacer (2023 Badlands)
J_Bizzzle
James
Reno, NV
'23 Bronco, '66 Mustang, '73 K10
For anyone that wishes the steering wheel telescoped further out, I've got a solution for you!
I always wanted the steering wheel to come out further (and do on most cars I've driven). Especially on longer drives, but also in general, I feel as though I have to have my either my legs or arms in an uncomfortable position. I tried installing the seat spacers under the front of the seat to better support my thighs, and it definitely helped, but was not the complete solution.
I've looked for steering wheel spacers but didn't have much success for anything Bronco specific. Then I came across SpacerShop.com, and they had some spacers for modern Ford vehicles. I reached out and they got back to me and said they did a deep dive and that the Mustang S550 spacer ( Ford Mustang S550 Steering wheel spacer - Spacershop) would most likely work, but they weren't sure if the wiring would be long enough and that they didn't have a wire extender ready for the Bronco (but might in September). I decided to go for it and sure enough, it worked! The wires were just baaarrreeeelyyy long enough. I don't know if it is 100% the best looking mod, but it was not designed for the Bronco, and so I have no real complaints there. The product is absolutely 100% functional though.
There are 3 main "gripes" I have which will hopefully be addressed if they release a Bronco specific version.
1. The spacers sticks up above the steering wheel very slightly, which just isn't ideal aesthetically.
2. There is a small gap between the spacer and the column, which doesn't look the best and might allow for slightly more dust intrusion than it would have originally. This was not a sealed surface originally, so not hugely concerning, but I might try to 3D print something to fill the gap.
3. The turn signal lever is now a long way from the steering wheel. This is not a fault of the product, but still something I'd like to address. I am going to try 3D printing a little extender arm to be able to flick the lever like normal.
I was having trouble posting the pictures directly here, so here is an imgur link:
There are videos out there on how to remove the airbag and steering wheel. The one comment I have is that one thing that helped me disconnect the spring tabs and remove the air bag, was to actually push down on the horn/airbag while trying to push the spring release. It made it much easier to get the allen key to actually hit the spring.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
It certainly looks good enough for the comfort it'll surely provide! This will be great for you tall folks. It would be nice to have the wheel further back so that I can stretch my legs a little nicer while still sitting comfortably with my arm on the door sill and center arm rest.
J_Bizzzle
J_Bizzzle
James
Reno, NV
It is 100% worth it! I did also find the seat spacers helped and they are a much cheaper solution to start with.
T800
Rick
Riverside, CA
OBX SAS Avalanche Gray
I might pester them to perfect something for the Bronco. I've had mine for a week and having trouble getting comfortable. I'm 6'. Sounds similar to you, if I have the seat close enough to the steering wheel, I don't have enough leg room. I was thinking yesterday that this would be fixed if the steering wheel would come out a little further.
Even searched on here and found people saying they're taller than 6' and having no problem (which I don't understand lol). So just figured I need to get used to it. I have the seat as close to the ground as it will get and have the steering wheel as high as it will get. So this would likely bridge the gap.
J_Bizzzle
J_Bizzzle
James
Reno, NV
Good to have a little confirmation, I'm 6' as well. I posted on reddit ( Steering Wheel Spacer - for all the tall bois out there : r/FordBronco) and got nothing but pushback. Was quite surprised because I've sworn I've seen others talk about the same issue. Was really just trying to provide some insight for others.
It will be interesting to see if they make a Bronco specific one. Sounds like they have plans to provide an extender for the wiring, but wasn't clear if they were also going to make a whole new spacer.
T800
Rick
Riverside, CA
I emailed them.
Yeah, I've had this problem in the past too. Actually traded in a Honda Accord after about a year and a half because I could never get comfortable. It was a 2000 and didn't have a telescoping wheel back then.
It's something that's near impossible to figure out on a test drive. After a week of driving, I was thinking about the Accord and how my wife would kill me lol. I even bought an OBX with the power seats hoping to minimize issues.
I posted in the Reddit thread too. Still scratching my head on this one.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I always wished the steering wheel came out a little further as well. I will also email them and put in another request for a Bronco-specific version.
I love the idea of the one you installed but I am a little too OCD to live with the sticking up bump and the gap.
J_Bizzzle
J_Bizzzle
James
Reno, NV
Let me know if they end up making one. Maybe they'll send me one eventually since I kind of guiney pigged this one.
Naxster
Dayton
None
I found my next mod. Thank you! Never enough leg room, but this should help a ton.
T800
Rick
Riverside, CA
They replied to me and added this option to their website:
https://spacershop.com/product/ford-bronco-mk6-steering-wheel-spacer/
Still trying to find the 'sweet spot', but also keep hitting my knee on the steering column with it moved all the way to the top.
How much is it? According to Google currency conversion, it's $23,973.42 lol.
I figure that's really $239?
Naxster
Dayton
None
Europe uses commas like we use periods. So if you're going to convert the currency, type in 210.00 instead of 210,00
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I got a similar response: "Hi, another customer just installed one and sent pics, so we could update the website. You can see and order the spacer for the Bronco at this link"
So it sounds like they are just going to roll with this one and no plans to create a truly Bronco specific version
T800
Rick
Riverside, CA
Yes, sounds like they copied and pasted the same response for both of us.
I seem to be finding more of a 'sweet' spot. One of the reasons I picked the OBX over the BL is because it made the electric seats affordable, but then lose the rails, sway bar disco. So previously, I had the seat lower to the ground.
Trying to compare seat position with my Jeep: I raised the seat up which lets my legs drop down more instead of going straight out. Because I was hitting my knee on the steering column when moving from gas to brake:
At a stop light, I moved my leg so it was under the column. Then adjusted the tilt so my knee would barely clear it (almost all the way up). Still not completely dialed in, but feel like I'm close.
If someone has the manual seats, I think the seat jackers for the front might be the key. I saw a Youtube video where someone bought a single electric drivers seat from a wrecked Bronco. It's a direct swap, so that could be an option for some.
Regarding the adapter, it would definitely be more appealing if they made a trim piece to cover the gap. Hopefully the next model of Bronco will allow at least another inch or more of telescoping. Though looks like many that are having this problem are exactly 6' tall. People that are 6' 2" don't seem to have this problem. We are the anomaly that Ford didn't test for.
