Show off your HAM or GMRS setup
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
I went with he 41 watt Rugged radio and Bronco mounting kit.
https://www.ruggedradios.com/produc...o-for-ford-bronco?_pos=1&_fid=60ec9fa2f&_ss=c
If I did it again, I'd put the antenna on the back and route the cables up to the glovebox (radio) and battery (power). Right now my antenna is on the front left tied down thing that comes with the bronco. sorry, I forget the proper noun for that black rectangular thing.
You need to prepare yourself mentally and physically to also program your radio. Not hard, but you gotta do it. Look into things like MyGMRS.com and start to understand what repeaters are in your area. Sounds like you know this stuff already b/c you're talking about HAM and GMRS is lighter than that.
FSUMcFly
Justin
Atlanta
www.instagram.com
Bronco Ordered
Here’s my setup, still working on getting my technician license but had to have VHF for a Baja run with EXO. Took out my midland mx275 and wanted a radio that can do GMRS and VHF with a mars mod. Went with the Yaesu FTM500 installed above the glove box with the Mountains2Metal bracket, head unit installed on a Proclip phone mount with RAM mount swivel, and comet SR2x4 antenna on the A pillar light mount.
Ford Bronco Show off your HAM or GMRS setup IMG_8968
Ford Bronco Show off your HAM or GMRS setup IMG_8928
Ford Bronco Show off your HAM or GMRS setup IMG_8889
Ford Bronco Show off your HAM or GMRS setup IMG_8896
bhoth1011
2023 Bronco Wildtrak 4 dr
Here is my Ham Radio Icom ID-5100A setup in my 2023 Wildtrak.
Ford Bronco Show off your HAM or GMRS setup IMG_7643
Ford Bronco Show off your HAM or GMRS setup IMG_7642
Ford Bronco Show off your HAM or GMRS setup IMG_7641
Ford Bronco Show off your HAM or GMRS setup IMG_7640
Ford Bronco Show off your HAM or GMRS setup IMG_7639
Ford Bronco Show off your HAM or GMRS setup IMG_7638
Ford Bronco Show off your HAM or GMRS setup IMG_7637
Ford Bronco Show off your HAM or GMRS setup IMG_7636
Ford Bronco Show off your HAM or GMRS setup IMG_7635
RanDar
Randy
Silver City, NM
76 Bronco wagon, 2002 Chevy Silverado, 2023 Bronco
No pictures (old guy), but... Wouxun kg-1000, 50W radio with removeable control head is mounted under the driver side dash. Not easy job for an OFBG, but there's lots of room there. You could easily stack 2 radio bodies in that location. Control head and mic mounted overhead above drivers sun visor. Probably enough room there to mount 2 control heads SXS. Short antenna cable run to a Rugged Radios mirror antenna mount for Bronco, a little pricey, but looks clean. Rugged Radios "UHF and GMRS" antenna with spring base. No tuning needed for antenna. Short antenna but performance is great. Besides using it on the trail, I check in weekly to a GMRS club that covers a wide area in New Mexico and Arizona via linked repeaters. The repeater closest to me (Jack's Peak) is 20 miles LOS distant with 3 mountain ridges at a higher elevation than I, between me and the repeater.
AirportDave
Denver, CO
2025 Badlands Sasquatch
New Bronco owner here (K1BRU), after several years of Jeep Rubicon ownership! Similar to my previous Jeep setups, installed my Yaesu FTM-150 control head using the 67D Bronco ball and mini arm. Radio mounted under the passenger side seat, with mic mounted next to start button using mic extension kit and adhesive mic holder. Teraflex tailgate antenna mount with Comet SS-680 SB antenna.
Ford Bronco Show off your HAM or GMRS setup IMG_2732
Ford Bronco Show off your HAM or GMRS setup IMG_2731
Ford Bronco Show off your HAM or GMRS setup IMG_2723
UncleBrad
Brad
2024 Bronco 2-DR Manual
Great solution. And your dual-bander antenna will clear your garage door as well.
HPNQ420
Wauwatosa, WI
Yaesu FTM-6000 (Radio above glovebox, control head on a Lido/Proclip USA mount, mic on a MagicMic magnet) & a Rugged Radios GMRS (with their mounting kit). Thinking about an HF setup but I realize that would take me 60% of the way to an M210.
Ford Bronco Show off your HAM or GMRS setup IMG_2277
Ford Bronco Show off your HAM or GMRS setup IMG_2278
Ford Bronco Show off your HAM or GMRS setup IMG_2276
Ford Bronco Show off your HAM or GMRS setup IMG_2271
Ford Bronco Show off your HAM or GMRS setup IMG_1984
BD6G
Everglades
IN
24 Bronco
Everglades
Rugged Radios G1 mounted on the Mountains 2 Metal console MOLLE, hand mic on a magnetic mic mount on a Bulletpoint arm and Stealth antenna mounted on a Mountains 2 Metal antenna mount on the SPV a pillar mount.
Ford Bronco Show off your HAM or GMRS setup IMG_8016
Ford Bronco Show off your HAM or GMRS setup IMG_8017
Ford Bronco Show off your HAM or GMRS setup IMG_8179
PrepVet
North Central WI
A bunch.
Very basic in my Bronco. It's more extensive; at least it will be again once I replace the power feed system in my PW.
Ford Bronco Show off your HAM or GMRS setup okk
Ford Bronco Show off your HAM or GMRS setup AA
