Deleted member 72780
Guest
Here is new picker with points budget and new table with Nitto added as MT option. Toyo seems to be top pick unless you dont spend all points. Can not say I disagree. I did not add cost on purpose here. I wont add any more as that is enough top picks from top brands.
FactorGoodyear Territory (Current OEM)Toyo Open Country A/T IIIYokohama Geolandar X-ATBFGoodrich KO3 (May Release)Mickey Thompson Legend EXPMickey Thompson Baja Boss A/TFalken Wildpeak A/T4WGeneral Grabber X3Cooper Discoverer S/T Maxx
StatusAvailableAvailableAvailableWaitlist (Est. May)AvailableAvailableAvailableAvailableAvailable
Size315/70R1735x11.50R17315/70R17315/70R17315/70R1735x12.50R17315/70R1735x12.50R17 (C-Load size)315/70R17
Load RatingC (6-ply)C (6-ply)C (6-ply)C (6-ply)D (8-ply)D (8-ply)C (6-ply)C (6-ply)D (8-ply)
Weight~52 lbs (Lightest)~63 lbs~61 lbs (Ultra Light)~66-68 lbs (Est)~62 lbs~73 lbs~76 lbs (Heaviest)~78 lbs (Very Heavy)~66 lbs
Sidewall2-Ply2-Ply3-Ply (Geo-Shield)3-Ply (CoreGard)2-Ply (High Tensile)3-Ply (PowerPly XD)3-Ply (DURASPEC)3-Ply (Duragen)3-Ply (Armor-Tek3)
Balancing8.5 / 109.5 / 10 (Best)8.5 / 108.5 / 107.5 / 108.0 / 107.5 / 107.5 / 108.0 / 10
Wet Traction9.0 / 109.5 / 10 (Best)8.5 / 109.0 / 108.5 / 109.5 / 10 (Best)9.0 / 108.0 / 108.5 / 10
Winter/Snow7.5 / 109.0 / 10 (3PMSF)8.0 / 109.0 / 10 (3PMSF)8.5 / 10 (3PMSF)9.5 / 10 (Best)9.5 / 10 (Best)7.5 / 10 (M+S Only)8.0 / 10 (M+S, Studdable)
Road Noise6.5 / 10 (Loudest)9.0 / 10 (Quietest)7.5 / 108.5 / 107.0 / 108.5 / 108.5 / 107.0 / 10 (Mud Terrain hum)7.5 / 10 (Hybrid hum)
Ride Comfort9.5 / 1010 / 108.5 / 109.0 / 108.0 / 109.0 / 108.5 / 108.5 / 10 (Soft C-ply flex)8.5 / 10 (Good D-ply balance)
Durability4.0 / 108.0 / 109.0 / 1010 / 108.5 / 109.5 / 1010 / 109.5 / 109.5 / 10
WarrantyNone65,000 Miles45,000 Miles50,000 Miles50,000 Miles50,000 Miles60,000 MilesNoneNone
OVERALL7.3 / 109.2 / 108.8 / 109.1 / 108.4 / 109.1 / 109.0 / 108.2 / 108.6 / 10
Best Use CasePavement Princess / MPG Saver. Best if you prioritize fuel economy and ride comfort above all else and stick to pavement or light gravel.The High-Mileage Commuter. Best for Bronco owners who drive 90% on-road, face a lot of rain, and want a tire that is easy to balance and quiet.The Budget-Conscious Trail Rider. Best for someone who wants a tough 3-ply sidewall for rocks but wants to save money and weight compared to the heavy Mickey Thompsons.The "Do-It-All" Loyalist. Best for the driver who wants the gold-standard look and C-Load comfort but needs newer tech/wear-life than the old KO2.The Classic Overland Build. Best for D-Load stability when carrying moderate weight (overlanding gear) without jumping to a harsh E-Load ride.The Severe Weather Warrior. Best for deep snow, ice, and wet roads where traction is life-or-death, and you don't mind a heavier tire.The Heavy Hauler. Best if you tow a trailer or load your Bronco heavy; its HD durability is unmatched, though it is very heavy for a daily driver.The Dedicated Rock Crawler. Best for a "weekend toy" Bronco that lives in the mud and rocks and rarely sees highway miles.The Gravel Road Explorer. Best for long-distance durability on sharp gravel and dirt roads where puncture resistance (armor-tek3) matters more than snow grip.
CommentBest: Lightest weight (~52 lbs) and very comfortable.
Worst: Weak durability (thin sidewalls) and no treadwear warranty.
Best: Best daily driver (quietest, best wet traction, 65k warranty).
Worst: Weaker 2-ply sidewalls (less rock protection).
Best: Excellent strength-to-weight ratio (tough 3-ply sidewall but only ~61 lbs).
Worst: Louder and harder to balance than the Toyo.
Best: Combines extreme durability (3-ply) with a soft C-load ride.
Worst: Not available yet (must wait until approx. May).
Best: Stronger D-Load (8-ply) rating while staying lightweight.
Worst: Poor road manners (loudest and hardest to balance).
Best: Incredible snow/wet traction & bombproof 3-ply sidewall.
Worst: Heavier and wider than the 315/70R17 C-load options; tricky to balance.
Best: Indestructible (10/10 durability) and best in snow.
Worst: Extremely heavy (~76 lbs), which kills MPG.
Best: True C-load flexibility for rock crawling.Worst: Ironically heavier than most E-loads; will hurt MPG significantly.Best: A perfect "Goldilocks" tire; tougher than a C-load but softer riding than an E-load.Worst: Older tread design; technology is dated compared to the new AT3 XLT.
Link has budget of
https://colab.research.google.com/drive/17BlAgKQUgH4uckZJVPYRHXli2_FVj9pj?usp=sharing
The Daily Driver Winner: Toyo Open Country A/T III
The "Aggressive All-Rounder" Winner: Mickey Thompson Baja Boss A/T
The "Goldilocks" Winner: BFGoodrich KO3
A lot of this is subjective and some will destroy all tires and others will all get 60K. Ice and Mud are so subjective and driver dependant I stay away as I want to keep my truck in one piece.
Sloth
SWFL
2022 Bronco
AT tires only? Toyo Open Country RT Trails come in D load range.
timhood
Tim
Several
Was surprised the MTs came out lower on my list. In my mind, it was between the MT and KO3 (which was at the top).
I would call this a tire picker or tire guide rather than an estimater. I didn’t get any estimates. 😆
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
Good info, would've save me all that time comparing (I did end up getting Toyo OC AT3 35x11.50s)
Guest
I can estimate parts of running 76 pound tires on OEM suspensions long term.:sadface:
Baja Boss for the insane.
KO3s for enthusiast
and TOYO for daily drivers is my take away. I have two sets.
Balance quality should be a given in 2025 but Japan mastered it and BFG is mildly recoginizng they suck here.
Guest
scoring is -+/- 10 points and left cost off as I wanted to know performance. 1000 great value shopper brands out there made overseas.
Scott R Nelson
Meridian, ID
I'm planning to go with the Firestone Destination M/T2 when my Goodyears wear out. Didn't see that one on the list.
Agrod
SJ, PR
22 4dr OBX
My OEM tires went out at 17000 miles. Granted, I do drive quite aggressively, did "some" doughnuts in gravel/rocks, but they dry rotted and were out of round already. I swapped in a set of Falken Wildpeak A/T4W and couldn't be happier. Interesting about the Toyo Open Country A/T III that should be even comfier in the road.
timhood
Tim
Several
KO3s for enthusiast
I don’t count myself in the insane category, but I will do all but the 10-worst trails in the Moab book. My off-road tires need to be great with rocks, as lots of the local trails are littered with sharpies. I have some basic Goodyear ATs for my daily drivers, so the off-road tires can be more dedicated as long as they can handle a 4-hour drive without making us hate life and they aren’t so heavy that I can’t put them in the studs by myself (I change my tires myself). So far, the stock 33” KO2s fit that. When they wear out, I was planning to go to 35s since they will get only part time use.
Guest
Not too many worth comparing
Nitto grappler,
Goodyear Wrangler
Toyo RT
I just looked at at as trails are hours from me
