RockJock track rod bracket full suspension compression requirement
Tricky Mike
21 Bronco
as an alternative you could try the OME bracket
https://store.arbusa.com/rear-panhard-relocation-bracket-fk109/
It mounts differently so no compressed length restriction from what I have found.
I doubt it will work. I looked it over and it's the track bar end that is going to make contact. The solution is either dropping the frame side bracket, or a spacer on top of your coils to increase the effective compressed length. I'm leaning spacer so 37s don't stuff into the body as much.
I also have the Eibachs now so I'm in the same boat as @PWillette
These will all work fine for street driving but you're going to have a nasty bang if you ever get air.
Tricky Mike
21 Bronco
This also should give goooobs of droop combined with your height adjusters being threaded out to a minimal lift setting. I personally would like to end up about 2.5" all around. The minimum lift for rear Eibachs is 1.3" so a 1" spacer on top should be about perfect.
youloze
2023 Bronco Black Diamond
I considered that but they don’t sell a track bar yet for the bronco.
worked fine for me with the stock bar
Interesting. While it does have a different mounting orientation, the track bar is still sitting in the same location (above the OEM position)and I imagine would have the same clearance issue with the frame for suspensions that compress too much.
youloze
Agreed about both brackets basically being the same in terms of clearance.
I'm running the Eibach 2.0 but am running about 4" of lift, so I'm hoping I don't have the compression clearance issue. I'll find out next time I stuff the rear passenger haha.
PWillette
Parrie
Maine
This could be a good work around👍
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
Some quick articulation testing with the OME bracket. I’m on the bumpstop on the shock but not fully compressed and still have about 5” of clearance before frame contact. a jump test may still create an issue but time will tell.
Ford Bronco RockJock track rod bracket full suspension compression requirement E47DD643-B77E-4C51-A735-71E4BB3994E5
Ford Bronco RockJock track rod bracket full suspension compression requirement 2747CA3D-8ADD-4D38-99DD-3B596E7EA583
youloze
Thank you for this. What suspension are you running?
youloze
stock SAS bilsteins with dobinson front and rear 2” lift springs
I'd imagine I should be fine on Eibach 2.0 with 4" of lift then. Guess I'll find out haha. Thanks!
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I’m running ADS and the Rock Jock bracket. No issues seen flexing this thing out. ‘23 Wildtrak and swaybars still connected… I’d fully stuff the front with discos…
Ford Bronco RockJock track rod bracket full suspension compression requirement IMG_7773
Ford Bronco RockJock track rod bracket full suspension compression requirement IMG_7905
Ford Bronco RockJock track rod bracket full suspension compression requirement IMG_7907
Ford Bronco RockJock track rod bracket full suspension compression requirement IMG_7904
Ford Bronco RockJock track rod bracket full suspension compression requirement IMG_7903
Ford Bronco RockJock track rod bracket full suspension compression requirement IMG_7902
climb2descend
CA
15'F150
Welp, with the 4wp coilovers and fabtech relocation bracket I get contact with the frame when hitting full bump at speed booo. Kind of ridiculous that nobody makes a chassis side relocation bracket to resolve this issue.
Yaniv wildtrak
Yaniv
Israel
Ford bronco Wildtrak 2022
Hi.
I'm in the sam situation and have a question.
1. 2.5' at the top of the rear shock will not damage the shock
2. If I engrave a 2.5' thick aluminum spacer and put it with long screws from end to end, is this safe?
I saw that all the spacers on the internet from 2' and up come with a distribution of short screws on each side. why is it ?
Thank you for great discussion.
