Purchase HOSS 3.0 Suspension
wigglysqiggly
William
2023 Ford Bronco
I do recommend to buy an extra set of axel bolts just in case. The bolts are super soft and bent one.
luckily the dealership had a spare one
plipnoggen
plipnoggen
Pennsylvania
2023 Heritage Edition
2 door vs 4 doors suspension is not that much of a difference. I guess there is only 2 types of springs and i lucked out with the lighter springs set.
the suspension is night and day. I totally recommend the suspension if you can. So much smoother and not as harsh of a ride.
The suspension actually leveled out the car and now even all around.
i was able to score some for $1400 with like 600 miles on them
Was that just from a private seller?
CC1999
KS/OK
2023 Bronco, 2021 RAM TRX, 2023 GMC Denali HD
Looks like what I am needing to buy is the following.
I am planning to ask my Ford dealer to get me a quote on the parts.
I do have a wholesale part account with them, so prices should be a little under retail prices.
Needed parts list.
2-Door HOSS 3.0
  • Front
    • Struts: NB3Z-18124-A
    • Springs: NB3Z-5310-C
  • Rear
    • Struts: NB3Z-18125-A
    • Springs: NB3Z-5560-B
I have a high spec 2dr Badlands SAS with 2.7L and Tow pkg.
Would those part numbers be correct?
CC1999
KS/OK
No idea if this is accurate but look at the 4-doors the Badlands non-sas, and 2-door Sas Broncos with the 2.3 Engines, they show different rear springs with the tow package.
The Definitive Guide to 2021+ Bronco Ride & Lift Heights with Wheel & Tire Sizes | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
Based on the cookbook here I should have the following springs on my Bronco.
Front = MB3Z-5310-L
Rear = MB3Z-5560-C
If I understand what I am reading in this thread correctly the springs I have now would fit on the Fox HOSS 3.0 shocks.
Is that correct?
CC1999
KS/OK
The used set of take offs have totally different numbers.
Springs
NB3C-5310-AVB
NB3C-5534-AYB
Shocks
NB3C-18045-KC
CC1999
KS/OK
I found a Vin to a 2023 loaded Wildtrack and here are the part numbers it is showing.
Front
Part #: NB3-Z18124-A MSRP is showing $1003.64
Rear
Part #: NB3-Z18125-A MSRP showing $ 992.73
CC1999
KS/OK
How did you know if you got the lighter or the heavier springs with the takeoff set you bought?
BUCKIN6VA
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
If you're willing to wait a few weeks I will have a HOSS 3.0 take-off (from my '23 Wildtrak) with roughly 4,000 miles on them. Installing ICON Stage 6 suspension, so I will have the front & rear shocks, springs and control arms available.
CC1999
KS/OK
Thanks, but I pulled the trigger on these this morning.
I just hope they fit ok.
Part numbers seem to be all over the place, and nothing seems very consistent.
These are off a 4dr.
I sure hope they fit and work like they should on my 2dr.
Ford Bronco Purchase HOSS 3.0 Suspension 1715026290353-s9
Ford Bronco Purchase HOSS 3.0 Suspension 1715026444254-cc
Ford Bronco Purchase HOSS 3.0 Suspension 1715026491818-33
Ford Bronco Purchase HOSS 3.0 Suspension 1715026457749-n
Ford Bronco Purchase HOSS 3.0 Suspension 1715026468398-ig
Ford Bronco Purchase HOSS 3.0 Suspension 1715026514801-1i
CC1999
KS/OK
Those are the AY springs that I have they work on the 2 or 4 door. The 5534-AV springs are for the broncos with tow pkg so they are a bit stiffer but you are good. If your lucky enough your front springs are 5310-AV but are most likely 5310-AY because of the modular front bumper.
The ones I bought today are AYB and AVB?
Does the B matter, if not then sounds like I have bought the softer 4dr springs which should be ideal for my 2dr if I am following the info in this thread correctly.
wigglysqiggly
William
2023 Ford Bronco
I’m
The spring code AY is soft and AV is heavy.
Since you have the 2.7 up front you should be ok.
i lucked out and got both AY since i have the 2.3
Ducati1098
Springs
NB3C-5310-AVB
NB3C-5534-AYB
Shocks
NB3C-18045-KC
Those are engineering part numbers, here are the corresponding service parts numbers:
NB3C-5310-AVB = NB3Z-5310-C
NB3C-5534-AYB = NB3Z-5560-B
NB3C-18045-KC = NB3Z-18124-B
Aliass24
No, your good to go that’s the softest setup your gonna get from a 4dr with hoss 3.0. They should work well on your 2dr let us know how it works out.
Aliass24
I’m
I’m
I have run multiple vins on both 2dr and 4dr wildtrak and all the 4drs in the heaviest setups with the heavier modular front bumper run the AY front springs but I have come across a few soft tops with the lighter capable bumper running the AV front springs also a few 2drs running the AV front springs so with that I would say AV’s on the front might be a bit lighter but either way it should be fine. They are the 5310-C springs.
