HOSS 3.0 suspension questions
42Jose
Jose
Greenville, sc
24 Bronco
So I saw a set of front and rear HOSS 3.0 fox coilovers from a wildtrak for sale. I have a non sasquatch Black Diamond, My question is can I just swap over the coiloves and gain height, do I need anything besides the coilover for the swap (UCA, brackets, Etc...)? Wanting the more aggressive look with 35's; with the rare excursion onto mountain or desert trails...
RoseLane4
PA
Subaru WRX, Subaru Forester
Op,
As long as your rig is the same wheelbase & motor/transmission as the WildTrack (4 door w/2.7 for example) - yes!
HalfmuleFarmer
Thomas
2025 Badlands
There’s not much of a “look” to the Hoss 3.0 Fox setup, unless you are crawling around under the vehicle. But performance-wise, a solid 👍🏻
  • Like
Reactions: MDH
TruckCamper
Peter
Kingman AZ
It will fit regardless of configuration. You may get more/less lift depending on configuration differences. Bolt on. Although... I'd compare to buying the entire package brand new from Ford Performance ~ $2,200 including rear sway bar and it will be ~1" taller.
MDH
Southern California
2017 mazda6
I’ve done this. You can just do the swap with nothing else and it will be a great improvement.
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
They will swap in, no issues.
You will need an alignment.
What are the specifics of your bronco?
Doors, engine, etc.
What number of doors on the Wildtrak the coilovers came off of?
I did the swap on my Heritage Edition.
42Jose
Jose
Greenville, sc
24 Bronco
Thanks everyone...
Way2Fast
Sam
Santa Maria, CA
I did this on my 2021 Wildtrak. Put on Toyo E series 35s. Much quieter and smoother ride on the freeway. Also much better in the dirt
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
R/T, M/T, A/T?
