- Gary
- Aug 18, 2024
- 35
- 552
- 446
- Costa Mesa CA
- 2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
- Badlands
I have installed my single brushless onboard air compressor. I installed the trigger wire directly to the AUX 6 switch without the ARB isolation switch. It works very well. However, I discovered the internal fan in the compressor continues to run (with the compressor off) after running the compressor a very short time. I am sure it is cooling the internals of the compressor which is fine, but that is another draw on the battery when the ignition is off. I don't know if installing the ARB isolation switch would stop that.
My greatest concern is if that fan comes on from heat soak from the engine. I don't want the fan running all the time. I may see if I can find some way to use the isolation switch to shut down all power to the compressor during times when I am not using it. Is this a bad idea?
I really don't want another drain source on the battery with the engine off. I don't like the fan running all the time either.
