New ARB Brushless Air Compressor
Gronco2024
Al-Pal
Bronco Wildtrak
What bracket options are there for this new compressor? Ordering one for a road trip and looking for options. The arb bracket seems to need modifications per their site. Any others or is everyone using the 4x4leds?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
CalvinT
Calvin
Phoenix, AZ
I looked at the brushless compressor at Flagstaff Overland Expo. The new compressor is smaller with a different form factor. It has a mounting plate. You can use the old mount if you drill holes to match the new mounting plate.
The new compressor is designed to be easier to remove.
Bikeric
Tulsa
2022 Badlands LUX on 37's
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I appears that the wire harness is different as well. Is it safe to assume that these are not plug-and-play with the existing "brushed" version? I would really appreciate the extra volume of the brushless, but I would not look forward to re-wiring front to back again.
Thanks,
Yes the wiring harness is different. Our kits never used an additional wiring harness though. You just use the harness that came with the compressor. Installation is pretty much identical with the only exception that the new brushless has a different harness. You have to install an (included) pressure switch and just plug that into the provided harness is all. Then you route it just like normal, over to the battery.
Instead of the PURPLE wire on the old twin being your TRIGGER to your upfitter, it's now a small red wire that is the trigger wire.
Otherwise our bracket works with the new brushless and installation is pretty much the same.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
No need to drill holes with our mount. Our existing mount works with the new Brushless.
jzweedyk
Moab, UT
2025 Lincoln Navigator
It would seem with the volume of "old" twins out there that they would make an adaptor to plug and play to change over to the new one. I would buy one in a minute if there was an adaptor, but I am not going though rewiring.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
what re wiring? You just have to run a new wire in the engine bay that takes 30 seconds
jzweedyk
Moab, UT
My compressor is mounted by the tailgate, so that run would take a while.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
this doesn’t fit the AGS mount - brushless uses a different mounting method and bolt pattern
Gronco2024
Al-Pal
Bronco Wildtrak
So what options do we have for the brushless compressor mount? just the one option for the bracket?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Gronco2024
Al-Pal
Bronco Wildtrak
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I understand. I just want to see the options available the others have used.
Well we like to stay up to date on this so when we designed our bracket we made sure it was compatible :)
Why not go with our bracket
PayHeedKU
Kansas
2025 CRV, 2000 Dodge Dakota, 2025 Bandlands (ordered)
Has anyone done an install of the new brushless compressor? I know the wiring harness is different from the standard one that there are several videos on so wondering if anyone has any pictures or videos of how the new harness connects - using the AUX switch - so I can make sure I’m doing mine right.
