ARB Brushless Air Compressors
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
The new ARB Brushless Air Compressors are now available from us!
Bronco Specific Onboard Compressor KIT
https://www.4x4truckleds.com/kr-off-road-air-compressor-engine-bay-kit-for-2021-ford-bronco/
Ford Bronco ARB Brushless Air Compressors 40-1000_10
TWIN BRUSHLESS
https://www.4x4truckleds.com/arb-br...ormance-12-volt-twin-air-compressor-ckblta12/
Ford Bronco ARB Brushless Air Compressors 1741367961585-y3
ARB has expanded its line of premium air compressors with the new Brushless series. Long known as a leader in onboard and portable air compressors, the new ARB Brushless lineup offers the ultimate air compressors, featuring brushless electric motors, built in fans for active cooling, cutting-edge smart technology, and an impressive 50% increase in air output compared to ARB’s current market-leading compressors. ARB Brushless Air Compressors are compatible with ARB’s existing range of air accessories and hose kits, and ARB Air Lockers, making upgrading your current air system super easy! ARB Brushless Air Compressors allow you to spend less time inflating, and more time having fun: Quick Air, More Adventures.
FEATURES & BENEFITS
  • 50% Increase in output – ARB Brushless boasts an additional 50% in output when compared to our current market leading ARB brushed compressor, meaning less time inflating and more time adventuring
  • Active Cooling – An active cooling system has been included with a fan in each motor/compressor assembly to achieve higher performance and longevity
  • Electronic Speed Control - Maintains optimum performance and operations across all pressure and ambient temperature conditions
  • Status Reporting – Live diagnostics via audio and visual alerts
  • Voltage and Overload Protection – Protects the compressor and power supply from damage due to voltage spikes, drops, fluctuations, overcurrent, and motor stalls
  • Continuity in Function – The ARB Brushless is constantly monitoring itself and can make adjustments to account for factors such as temperature and variations in vehicle charging systems
  • Quick-release Mounts – Onboard units can be removed using cam-lock quick-release mounts, making installation and removing simple process
  • Relays Eliminated – The inclusion of the brushless motor also means there is not any need for the mounting of relays, further reducing the install time
  • Smart Start - Staggered “Power-On” for twin variants to reduce the power spike at start up allowing brushless twins to start up on vehicles with smaller charging systems
SPECIFICATIONS
  • Volts: 12V
  • Width: 13.31 inch
  • Height: 6.69 inch
  • Length: 14.49 inch
  • Weight: 15.8 lb
  • Prop 65: No
  • Max Amps: 90
  • IP Rating: IP67 Water Resistant
  • Duty Cycle: 100%
  • Air Flow 0PSI: 9.18 CFM
  • Air Flow 29PSI: 6.20 CFM
  • Design: Brushless
  • Warranty: 3 YR
SINGLE BRUSHLESS
https://www.4x4truckleds.com/arb-br...rmance-12-volt-single-air-compressor-ckbla12/
Ford Bronco ARB Brushless Air Compressors 1741368013248-p4
FEATURES & BENEFITS
SPECIFICATIONS
  • Volts: 12V
  • Width: 10.83 inch
  • Height: 6.1 inch
  • Length: 12.8 inch
  • Weight: 9.5 lb
  • Prop 65: No
  • Max Amps: 45
  • Duty Cycle: 100%
  • Air Flow 0PSI: 4.59 CFM
  • Air Flow 29PSI: 3.10 CFM
  • Design: Brushless
  • Warranty: 3 YR
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Pretty cool albeit pricey. Maybe I’ll get one to test heat and times vs my old one.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Is the mounting configuration the same as the other twin? I have your under-hood bracket. Could I reuse it for the brushless version if I upgrade?
What about wiring? Can I simply remove the old compressor and drop this one in place and use the same wiring?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We don't know 100% yet. We BELIEVE it should be, otherwise ARB can't use ANY of their existing mounting systems out there. We'll know once our compressors arrive to us.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Appreciate the quick response. I reached out to ARB support for clarification. Not willing to drop $900 on a preorder if I have to get a new mounting solution as well.
Ben
Baltimore, MD
2023 Bronco Raptor
Here’s the response from ARB:
“Hello, you will need to rewire the brushless I am afraid. The connectors are a bit different, and the new compressor has some additional safety features built into it so there are some additional wires in the harness on the brushless vs the older brushed models. The mounting footprint is a bit different on the new ones as well, essentially you can absolutely use your existing bracket, but the feet on the new compressor are positioned a bit closer together as the compressor is a bit smaller than our old, so you would end up having to drill two new holes for one pair of the mounting feet, whether that be the front or rear pair of feet, but they will not quite line up to the existing holes in the bracket for the brushed models”
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
They may or may not work with our brackets. We have additional holes on our brackets (depending on when you ordered it from us that is).
It does use a new harness but that harness comes with the brushless.
Don't put the cart before the horse. Let us get a compressor in and test fit it to determine if it will/will not fit. Even if it does not fit we'll have an adapter plate available to adapt the new compressor's mounts to our existing brackets.
wigglysqiggly
William
2023 Ford Bronco
Will Wait on Testing Videos. Been wanting to get one but Price point vs Time. Can get one for $250 and be faster than this $900.
popo_patty
Caleb
Sacramento
I’ll try to get one done if I can get my hands on one. I have the regular single compressor from them and have access to thermal imaging and have a good baseline from a bunch of previous testing I did.
But yea, if the regular one works fine what’s the point of brushless? It advertises better cooling but my engine mounted single has yet to overheat or cause issues after 3 years and over 500 uses.
I’m not convinced it’s a worthwhile purchase but I’m also interested in seeing for myself.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Not quite. Also... the current ARB Twin Compressor is $640 and airs up a 35" tire from 15PSI to 35PSI in 60 seconds.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
These types of compressors are not even remotely the same as the ARB Onboard Air Compressors. Those are portable air compressors. This is an onboard air compressor. Different animal.
That's like comparing The engine on a Viper to the Engine in your F150. Both are engines right, but one is DIFFERENT then the other.
popo_patty
Caleb
Sacramento
I’ll try to get one out if I can get my hands on one. I have the regular single compressor from them and have access to thermal imaging and have a good baseline from a bunch of previous testing I did.
All are used to air up tires off-road and are considerations for someone looking to make a purchase. All have pros and cons. And the ARB single and dual are in this video. I’m a huge fan of ARB and run their single
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Again, completely different animals. Brushless is a different animal all together.
HikeBikeFish
Jonathan
Denver, CO
2021 Bronco Badlands
Anyone know what snorkel ARB is showing installed on the Bronco on the page for the brushless compressor? I haven't done a ton of research into this recently, but last I checked it wasn't possible (or at least it wasn't easily possible) to install a compressor and a snorkel.
Ford Bronco ARB Brushless Air Compressors 1741389494190-xx
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Thats a completely custom build. They cut a hole in the side of the body
