permanently disable 30 minute idle timeout
mrjking2000
mrjking2000
Justin
Loveland, CO
2022 Bronco BadSasquatch, 2019 F-250 PowerStroker
lol that's funny. my use case is different. when we're out on offroad recovery missions, and it's cold, i want the vehicle to stay running. some times we're out after dark and using the lights to see. or, we're doing heavy winching and i want to make sure i don't shut it off until i get back home as we can put a serious strain on the battery with heavy pulls.
i don't GAF what the EPA wants. It's my rig and i'll let it run for 3 days if I want to lol!
da_jokker
Jeep Wrangler JKUR
I may have figured it out!
in forscan, in the IPC config. You can disable auto idle engine shutdown, but it has a message attached that you must change one more thing in the BCM config. But it doesn't tell you what. Well after a little experimenting, it appears to be "police idle" that has to be enabled.
Once both were applied, the 30 minute max idle is off on every startup!
By god, if i want to let my vehicle idle for 2 hours, i want to let it idle for two hours!
I was pretty upset When I found this out as well. But then figured the few times I really needed to let the Bronco idol I could flip that switch.
A permanent fix, along with ASS removal is a welcomed Discovery.
I'm still debating how I want to disable ASS. Sounds like the force can is not really a disable, but more of "trick" by making it think you are using the steering/brake?
Stupid to spend $100 on the eliminator, but that might just be something I have to eat.. like getting better internal lighting.
mrjking2000
mrjking2000
Justin
Loveland, CO
i went the autostop eliminator route, one and done... button shows off on every vehicle startup.
da_jokker
Jeep Wrangler JKUR
Yeah.... That's my plan, but I just struggle with yet another $100 vs me doing a 2 step start.... Ignition + ASS.
At some point, I'm sure my laziness will win! :)
mrjking2000
mrjking2000
Justin
Loveland, CO
funny thing is, service manager even mentioned how many people hate that feature and want it disabled. and i said... you must not have heard about autostop eliminator. You should just supply that with new vehicle purchases for $100.
i could hear the wheels turning in his head haha!
mpeugeot
I bet most people would prefer to over pay for an ASS eliminator rather than Nitrogen fill on the tires.
mrjking2000
mrjking2000
Justin
Loveland, CO
update. i disabled that police idle this morning just as a test, and sure enough the 30 minute max idle was still disabled on startup. this does through a code in the system along the lines of "idle parameter not matching build" or something like that, i didn't write it down. but i cleared it and it didn't come back.
BigMeatsBronco
Allan
2021 FE 2 door
This is Fantastic let's add it to the main spreadsheet too.
Thanks for your efforts
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
I think it does something...because my door locks don't work anymore.... either on the fob, or switches.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Yikes. What's the "it" referenced here?
Wouldn't mind disabling the 30min timer but this symptom I don't need...
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
I figured it out. It works now. Anyway.
I had too many silent modes on, so I turned
All of them off one at
A time. Then wrote all the changes, and relearned the PCM
it had done something to the computer, had duplicate things on. I had all police dark modes I had all the silent modes enabled, so I undid everything!
and then it just left me with the option on the center stack to turn it off now under the 30 minute idle button. which is cool
So now, if I want to keep it on silent mode, I just leave the soft button on silent, and then if I don’t, the lights will flash, the lights in interior light will come on if I turn it off, so no more going in the computer to do that.
I already disabled the horn beeps so they are gone anyway.
Don’t ask me how all that happened but it did?
Forscan is all trial and error!!!
etmccaus86
Evan
Motor City
'22 BaseSquatch
So you're saying you're back to the stock configuration where it defaults to the 30-min timer upon startup - and if you then turn it off interior lights flash?!
I'm not sure I'm fully following what silent modes you enabled and what it's doing now.
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Sorry…
Sounds like I made it even more confusing. I’ll explain it the best way I can.
in a nutshell…
I came across that police idle thing, thinking that that overided
The 30 minute idol you guys are all talking about on the screen in the middle of settings on the display.
but what I came across was that playing with the Forscan settings,
I ended up getting an extra button underneath that 30 minute idol button that allows you to turn the silent mode on an off from the actual screen
And not in Forscan.
Has nothing to do with the idle time.
It’s an extra function that showed up in the menu from playing around in the computer.
It is normally not on the Bronco.
So in addition to fixing the lock problem with the doors, I ended up getting that extra “soft” button
By pushing and pulling in, clicking and messing with the computer, I got lucky is all I’m trying to say!!!
Ford Bronco permanently disable 30 minute idle timeout IMG_1484
Noodleneck
Darrin
Mississippi
Did you use the IPC data from the F-250? 720-01-01 subtract 8 from existing figure? I don’t see where you ever specified what you changed in the IPC.
mrjking2000
mrjking2000
Justin
Loveland, CO
no i didn't have to guess and change manual lines. i just shut off the idle shutdown and then enabled police idle. it runs all day now.
