Cannot set Powerpoint timeout
GroovyGeek
Boyan
'23 Bronco BD
A while back I had set the power point timeout on my Bronco to 4800s (the factory default) and it worked just fine, I could get power from the outlet in the back for about 1 hr after the main accessory power was turned off. However, I just tested it, and noticed that the power goes out as soon as the main accessory power is killed. Looked through the BdyCM module, settings are
Human readable:
Power Point Feature: enabled
Power Point Timeout, s: 4800
As-built
726-57-011C200100025A
Everything seems in order but the power in the back groes out immediately after the main accessory power is turned off. Any idea what may be the problem?
I am tempted to attempt restore from the Motorcraft as-built file, but Forscan tells me that the number of blocks does not match.
Suggestions?
dgorsett
colorado
F250, Mustang, Explorer
Be sure to check it after a few hours, and start the engine, not just Acc. I wired some lights to mine and kept messing with it, after a while it would no longer stay on. I tried again in the morning after a start and all is good. I think either it was tired of me messing with it or it went into battery save because I had run it so much during my test.
PS I know nothing of Forscan
GroovyGeek
Boyan
'23 Bronco BD
It was the battery. While I was messing with Forscan it dropped to a level that caused the power point to be disabled as soon as acc was off.
It would be nice if there was some sort of notification that these things happen to avoid issues like this. Not just all of a sudden stuff stops working
