Mossback
Andrew
Shoreline, WA
24 Bronco
I connected the power for the light to the solenoid that interrupts power to the winch. So, when I turn the Auxiliary switch on to power the winch, the light comes on. The solenoid I use is just a 500a continuous duty solenoid from Amazon.
Amazon.com: 500 Amp Isolator Battery Isolator Relay for Continuous Battery Isolator Mobile Audio Relay, 500A Relay and Isolator 12v Battery Disconnect Relay : Automotive
Where did you mount the Solenoid? I kind of poked around for a logical place and did not find a satisfactory spot in the engine bay. The fender area looks most promising, but I will need to fab a mounting plate to bolt it to. For now, I have it directly to the battery. I will tap the winch light to something DBT, maybe AUX6.
brnc_o_vrlndr
Casey
Southeast Michigan
2021 Ford Bronco Badlands 4-dr non-Sasquatch 7-spd
I put it on the driver side fender. I modified the bracket to make it work, but it has served me well for a few years.
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_9739
SierraBronco
Just finished this up. Had to drop the mount a half inch to get it to work. Then buy longer M12 x 1.75 bolts to ensure they threaded correctly to the nut. Also had to clearance the mount so that it wouldn’t be touching the intercooler manifolding. If you’re winching there will likely be deflection, especially with the shims, soooooooooo let’s try to save that stuff.
The fairlead that comes with the winch has a smaller opening, but we’re running the Yankum fairlead. So we had to cut that out as well.
Hammerbuilt tells me they are currently redesigning the mount to accommodate the Mishimoto intercooler. And now they will look at the fairlead opening too.
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_1283
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_1298
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_1299
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_1300
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_1301
brnc_o_vrlndr
Casey
Southeast Michigan
I put a pretty significant side load on a pull and bent the fairlead bracket. Thankfully, I was able to straighten it and I threw several 1.25” corner gussets in (don’t mind the booger welds). I put another side load (though not as bad) and had zero movement.
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_9550
Ford Bronco NEW Hammer Built High Clearance Hidden Winch IMG_9556
SierraBronco
Dangit. And you’re running the same fairlead I am. Couldn’t use a block for redirect?
Hummell
Adam
Charlotte, NC
Looks awesome!!!
brnc_o_vrlndr
Casey
Southeast Michigan
I had the normal Yankum fairlead, but moved to the competition size fairlead for this bracket. No, unfortunately, there was nothing else to anchor to and redirect. It was a bad situation all around.
Hedrock
Rome
4dr EG Black Diamond
@DoYouBronco i get a 404 on your site now for the hidden winch. Was thinking about picking it up as a fall project - are you planning to bring it back?
Ratfink33
Chicagoland
2024 Bronco Heritage Limited 2 door
Ha!! I literally just went there now myself to order the setup because I finally found a bumper I want to use. Then came here through Google searches to ask the same thing. Lol. My hope is that the mount also works with the CVF high mount setup since that's the intercooler I have.
Hedrock
Rome
Yeah I’ve been eyeing it since they announced, and I finally have the cash and the need to be able to self-recover now that I’m in CO.
Way sexier imo than any of the winch bumpers I’ve seen and an excuse for better boost temps with the high mount…
GreyZ
Gulf South Louisiana
This is the exact reason when I built mine that the fairlead mount has no bends and is also tied into the lateral plate the winch sits on. Hammers design is pretty good, but some of the load paths leave alot to be deisred.
Ratfink33
Chicagoland
See thing is I also built my setup to have a hidden winch like this. My bumper doesn't even have the ability to add a winch on it! I just hope they come out with something soon. Or someone else comes out with something similar. I have zero ability to do that kinda fab work in my garage sadly.
Hedrock
Rome
Do you have frame horn reinforcements too? Or did the frame/mounting bracket hold up fine, with load transferred to the fairlead bracket?
brnc_o_vrlndr
Casey
Southeast Michigan
They
the frame horns are reinforced. Just with the LOD or LOBO (can’t recall which one) towing reinforcement. More for straight line reinforcement, but better than nothing.
