IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
This definitely looks like a sweet setup! I'm curious if this winch will fit. It seems like it might be an extremely tight fit on the length, and I'm not sure if the mounting holes are in the same spot.
https://www.warriorwinches.com/prod...ai-v2-short-drum-winch?variant=44746910794038
Could be a more costly alternative to the other options currently available though.
I know this is designed to be used with the modular bumper, however it seems like @5GENIDN was able to make it work with the capable bumper with some slight modifications.
I looked at warrior when trying to find compatible winches but decided against it since the control box doesn’t look removable. And yes this winch mount is a confirmed fit with both the modular AND capable bumper!
The warrior winch is a little bigger and wouldn't fit this setup. However it would fit (between the tubes) if you are running the Wagner IC as it takes up less space then the Mishimoto IC. It would require a wider winch mount and if you have ACC you would be SOL.
I spoke to warrior awhile back and the control box is removable. That has been my plan all along to build one similar to this that fits the warrior winch.
5GENIDN
Idaho
No bumper modifications at all.... Fit like a glove to the capable. I do not know if your warrior winch would fit.... I think there was about 17 inches in width available. I will say though the Mile Marker winch is a brand new design that I am really impressed with.
JC-
Josh
2024 Heritage Bronco
I see the mount is now out of stock, what is the estimated wait for the next run? Thanks!
TXDOZER
Les
El Paso TX
2022 Bronco Basesquatch & 2020 Escalade
What other hidden winch mounts are there? RC and Lobo, and I believe Lobo does not wreck the approach angle
RC is not terrible on approach angle
DoYouBronco
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Would this work with the @Turn Offroad Hyperlyte Front Bumper & Skid Plate?
It works with the ADD pro bolt on, any aftermarket bumper may require customization of the fairlead bracket.
sending you a pm with more details.
telenerd
Laramie
Subaru
Didn’t read all the posts. How do you get to the winch lever to allow it to free spool? What about attaching the remote so I can move winch in or out?
5GENIDN
Idaho
Free spool lever is easily accessible from the passenger wheel well since the winch is inverted and the lever is at the bottom.
There is a capped plug for the remote that mounts right next to the fairlead BUT there is also a spooling switch that is mounted inside the cab. I mounted mine on the top of the dash right next to my hero buttons.
telenerd
Laramie
Subaru
Thanks buddy. Would you mind posting some pics?
5GENIDN
Idaho
took these just for you....
first is the free spool lever. fairly easy to reach from passenger side wheel well.
Ford Bronco NEW Hammer Built High Clearance Hidden Winch free spool lever
second is the wired remote connection... It is the "cap" on the right side of the fairlead.
Ford Bronco NEW Hammer Built High Clearance Hidden Winch remote connection
And then there is the in cab control switch.... I mounted mine on the drivers side of the "hero" switches on the dash.
Ford Bronco NEW Hammer Built High Clearance Hidden Winch in cab spooling switch
DoYouBronco
DoYouBronco
Tyson
El Paso
hpbuilt.shop
The lever can be accessed by reaching your hand behind the skid plate. One can also drill a hole in the skid plate to access it from the bottom
