Texasgrillchef
Gary
Dallas, Tx
Bronco Badlands, Harley Trike, Mustang
And you can still put your roof on with this thing on, or u have to remove it to put your roof on?
Easy-v
U S A
BadSquatch
Anyone have any tips or tricks on removing the C Pillar moulding? Seems like you have to at least remove some additional moulding prior to removing the c pillar cross bar moulding....
0ne
Nate
CO
Flex
Moredoor 2022+ only unless you want to get crafty and drill, threadsert, etc. I bought the rear only roll bar brace kit thinking it would work on two door but the roll bar angle is different and the roll bar would need to be drilled/threaded. I’m in Denver Colorado and would sell for $400 if there’s someone local or coming through that’s interested. To ship it would be a pretty penny as the box needed to ship is huge but not particularly heavy. Let me know, thanks.
Ford Bronco New Ford Performance B-Bow & C-Bow Brace Kit IMG_1499
Ford Bronco New Ford Performance B-Bow & C-Bow Brace Kit IMG_1537
Ford Bronco New Ford Performance B-Bow & C-Bow Brace Kit IMG_1601
Ford Bronco New Ford Performance B-Bow & C-Bow Brace Kit IMG_1503
Ford Bronco New Ford Performance B-Bow & C-Bow Brace Kit IMG_1504
Ford Bronco New Ford Performance B-Bow & C-Bow Brace Kit IMG_1536
Ninjak
Miami
0ne
Nate
CO
Flex
The bummer with the front overhead B pillar kits from Ford and others is with the top down the true fully open top/air/sky experience is ruined by the cross bar(s) right over your head. The rear kit does have merits in triangulating the rear roll bar section which probably provides some additional rear gate/hinge/spare tire mount rigidity.
coadr
Coady
Denver, CO
2022 Ford Bronco Badlands
I could be interested! Just need to determine if it works with my AAL cargo shelf first.
0ne
Nate
CO
Flex
I’d be happy to mock it up with you. If the shelf uses any of the three threaded holes below the speaker housings on the downward rearmost roll bar tubes then probably not…
0ne
Nate
CO
Flex
Looks like AAL has a version for BRaptor which comes with the same brace from the factory so if you’re really wanting the brace you might be able to get BRaptor brackets from AAL.
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
I'm definitely interested. I live down in Colorado Springs, was planning to drive up there soon to go to Microcenter. Got all the hardware from the kit?
Wildruby
Canada
My 42 dodge flexed so much the tailgate would open on big bumps
and no it wasn’t work out bushings
it wasn’t designed to do 75 either
moving the flex makes other issues too
I need more of this in my life? More pics and specs!
mcinfantry
Lee
Louisiana
Badlands 2 door
Cummins 4bt aftercooled
4l80e
60 front
14 bolt rear
4.88 gears
Discs front and rear
Milemarker hydraulic winch
Power windows
Hydro steering assist
Seating for 8.
38.7” Michelin LAV tires on Hutchinson beablocks
Air conditioning
Stereo
On board air and arb air lockers
