BRONCO B & C BOW BRACE KIT
i911fire
Ryan
Kansas
2023 Code Orange BRaptor
So I was really excited when I saw that the Raptor braces so I ordered them (SKU: M20201CBBK). The parts have come in but I have noticed that I do not have the thread inserts in my roll bar for them to bolt to. Any hope of drilling and placing thread inserts into them?
Rivet nuts.
i911fire
i911fire
Ryan
Kansas
I read that the roll bars are made of "boron steel". I was just assuming that the should be more difficult to drill and put the thread inserts in. Looking of anyone that has drilled their roll bars.
WheresMyBronco
Los Angeles
2023 Badlands
I think if you use the right drill bits, work your way up in bit/hole size, and use a good coolant or take your time so it's not always hot, you should be able to do it.
Disclaimer: I haven't drilled into boron steel before but that's just my experience with similar metals.
Post an update when you get it installed!
5GENIDN
Joe
Idaho
Yes it takes a while..... Patience and pressure and a couple sharp bits. Start with a much smaller bit and go larger and larger. it takes time.
AJITO
AJ
Baltimore
2022 Bronco Wildtrak
Is this compatible with aftermarket 6' / 6.5' speaker pods?
8421dave
SoCal
07 Sequoia, 20 Volvo S60, 62 Impala Wagon, 70 El Camino
Order a set of cobalt drills as these are way better for this application than standard high speed steel drills. You could also use solid carbide twist drills but are typically expensive and brittle…easy to break using in a hand drill.
Cobalt drills on Amazon.
BOSCH 14-Piece Cobalt M42 Metal Drill Bit Set for Drilling Stainless Steel, Cast Iron, Titanium, Light Metal
https://a.co/d/0M5siRl
