MPGs After Belly Skids?
Roofus
Swamp
M3/Bronco
After getting my NVM skids on and giving it a fresh fill up and a week of driving I’ve seen a drop in MPG from about 17.5 down to 14.7. Wow! Seems like a big loss just adding 80lbs, but I guess aerodynamics could be having an effect?
Just curious what others are seeing after getting their belly skids on?
Fordified1
Bob
Mid South Texas
Seems odd. And wouldn’t belly skids help aerodynamics instead of hurt?
HoosierDaddy
__ Eric
NW. Indiana
If the belly skids create a smoother surface down there, you'd get better mileage.
If they are aerodynamically all fubar'd, it'll go down.
I suspect there are other things at work here besides adding 80lbs of belly skids.
GTTom
Tom
New Hampshire
2023 Bronco Wildtrak
Agree ^
Adding 80 lbs is like just taking my dog for a ride. He doesn't hurt my milage:). Either aerodynamics is worse or other things at play. Maybe check your mileage for longer period of time or a whole tank then compare.
Tilzbow
NV
GM Sierra Diesel Pick Up
I added full set of JCR skids, a JCR bumper, a winch and a roof rack and my mileage wasn't affected at all. The total weight addition, compared to stock, was 208# which is about the weight of a passenger. The weight did create alignment issues though but those were adjusted by my local 4x shop as soon as I noticed tire wear.
I doubt the MPG has anything to do with the skids.
Roofus
Roofus
Swamp
M3/Bronco
Agree ^
Yeah, exactly. My wife weighs 105 (don’t tell her I told you). So that was my first thought as well. The skids should have been no worse than having another passenger in the truck. And the skids create a very smooth surface.
Here’s what’s even more crazy to me. I put all of the boxes for this stuff in my truck and drove 8hrs to my other property so I’d have a garage to work in. I got 17.5 all the way home. So it’s like when I carried the weight in storage it was fine. When I bolted it on it must have gotten much heavier. 😜😂
Other than skids I also installed 74Weld steering stage 1, e-swaybar disconnect, and Icon tie rods. I don’t understand how in the world any of that would be affecting mpg. 🤷🏻‍♂️
‘21OBX
90Bronco19
2022 bronco outer banks
Alignment off just a touch could eat some mpg, Is it up hill one way?
Fordified1
Bob
Mid South Texas
Lol no both ways. 😉 But alignment change seems plausible.
Roofus
Roofus
Swamp
M3/Bronco
I'm working with similar additions. Full NVM belly skids, rear diff skid, shock skids, tailgate reinforcement w/35, RC hidden winch mount and winch, and trailrax half rack. I mean at worst we're talking a few hundred pounds.
Roofus
Roofus
Swamp
M3/Bronco
Okay, that's a flag for me for sure. I took it to Ford for an alignment the day after we got the suspension/skids done. And then the next day on the drive home at interstate speeds I was complaining that they did a piss poor job bc it was noticeably pulling to the right if I took my hands off the wheels.
So the problem might be that I'm dragging some rubber down the road, huh? Unfortunately, I can't take it back to the dealer that did the alignment bc I work out of state and that dealer is near my permanent residence and I won't be back for two months. I'll ask the local guys for a good recommendation around here.
Anywho, good flag! Thanks!
Fmuguira
Frank
Idaho
Jeep TJ
I don’t think there’s apples to apples on comparison. Do a few more tanks of fuel, try to replicate the driving conditions, then if still 3 mpg less start the hunt for “what the he_l” happened !!!
ksdon
kansas
Well, when you are stuck on a rock and spinning tires, you will be getting Zero MPG.
Many vehicles have a carpet type mat attached undernearth to supposedly help air flow. Maybe skid plates also help. But either way, a skid plate on the trail is important enough to have even if it reduces MPG.
Gluestick
Josh
Nashville
instagram.com
Check your tire pressure as well. We've had a few cooler mornings here last week (false-alarm 1st faux fall), and all our vehicles tire pressure was reading several lbs lower. I'm currently got the bronco intentionally between 32-35 psi for mixed dirt/pavement use and my mpg has noticeably suffered. Back up to 39psi and i get that mpg right back.
