MPG - Why so bad?
Original Bender
Brent
Wyoming
22’ Badsquatch 2.3 Area 51 4D
Not sure about Colorado, but when I lived in the Northeast they would switch to "winter gas mix" in the late fall. This had a higher ethanol percentage, and would kill my mileage.
I’m in oil and gas. It’s exactly this. Because people still drive carbureted vehicles, in colder climates, they have to keep vapor pressure up in the fuel so they can start easily. They do this by using more butane in the winter blend/mix as it has a lower temperature boiling point than higher BTU natural gasolines. If everything was fuel injected they wouldn’t need to do this as mechanical spraying atomizes it enough to start when cold. Direct injection even in gasoline allows for much denser hydrocarbons such as diesel. This is why you can’t have a carburetor on a diesel.
23OBX2.7
AB Canada
2023 Bronco
Ask around to see what fuel brand Porsche and Ferrari owners are using in your area. One of the service depts or salepersons will tell you.
I have noticed a huge difference with high ethanol, which govts love becaue effeciency drops, use more fuel and they make a lot more gas tax revenue.
After FP tune my effeciency went up a lot.
Jossman 2026
Monument,CO
2022 Bronco,2013 F150,2011 Mustang +2006 HD
Was told years ago every 1000' in elevation robs 3% of HP.Fuel injection keeps the air/fuel ratio in balance but you drive harder to compensate for HP loss.
Ford Bronco MPG - Why so bad? Imag
Kini
2025 Bronco
Western Slope CO ~6000 ft, 2025 Sasq 4-door. 16-18 in winter, 18-20 summer, 85 octane.
Kini
2025 Bronco
One other variable for me, I used to be able to get 21-22mpg in the Denver area, but after installing the Ford roof rails, I'm now only getting 18-19mpg. Wind resistance?
Ah, you made the brick bigger......
Desmolicious
SoCal
2025 Bronco HE, MX5
The sticker on the inside of the fuel cover says 87+ and you are running 85?
Pops
North of Seattle
2025 2-door, Sas, Mid Pkg.
My milage keeps going down too, about 5mpg to 7mpg lower than the first 3,000 miles. No matter how careful I drive or road conditions. :curse:
OTA updates or something?
I have the OEM rack, and took the first cross bar off -- no MPG change.
(I have the cross bar off because I am working on making an antenna mount there).
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
At 6000 - 12,000 ft it doesn't need more than regular. If I go down I'll run premium.
This is the case with an N/A motor that operates solely off of vacuum, not so much with a motor that gets force fed any amount of boost.
Run 87.
23OBX2.7
AB Canada
2023 Bronco
13 in city 19 hwy FP tune 93 octane.
