Motor Mount Fluid?
bigal77usa
2022 Ford Bronco
I'm chasing down a phantom leak. Can anyone confirm if the motor mounts on the 2.7 contain fluid?
adamruiz2001
SoCal
Ford SVT Lightning
I have no clue on your question, but why not just take it over to Ford and let them give it a once over since I assume you are still under warranty?
Ducati1098
Pretty sure they don't. They're just rubber mounts
Mjasi3
Chicago
Never heard of motor mounts containing liquid? Is that a thing?
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Not sure but fyi ford has used fluid filled bushings in the past. The LCA bushings on my old mustang were fluid filled.
BroncoChallenger
2024 Bronco
Yes it is a thing, and has been for a LONG time. Late 90's+ GM W-bodies (Grand Prix, Impala, Century, Regal) had a fluid-filled lower motor mount. It wasn't usually an issue, but occasionally they would rupture and leak until there was no fluid left. The motor would vibrate quite a bit more because of that, but unless you knew what you were looking for (and cleaned that lower motor mount off) you might not know it had happened and thought you had an oil leak from the motor.
As for the Bronco...no idea if any of the bushings/mounts are fluid-filled.
V1Rotate
Brevard, NC
2022 Wildtrak
My wife's grand cherokee has fluid filled motor mounts. Huge PITA when they leak
flip
Phil
IN
www.ruxerparts.com
Fords
The fluid is usually has a very high viscosity and about the consistency of honey or cold maple syrup. We've seen a few spill their guts, none on bronco, and usually accompanied by a vibration or "thump" when going from forward to reverse.
JBlanco
Julio
Charlotte NC
Yes, there are also active motor mounts that change their frequency to neutralize the vibrations of the engine.
onetong8r
Adrian
Hilliard, FL
'21 Bronco, '10 Jeep JK, VW Golf R, VW Tiguan, VW CC, '71 VW Beetle
Did you ever get this resolved? I did an oil change on my 2021 2.3 yesterday and when I pulled the skid plate off the front passenger side axle had some oil on it and I first thought it was from the power steering unit but all I can figure is it dripped down from above and the only thing above it the passenger side motor mount. Mine has 91k miles and it dry with zero leaks at the last oil change so definitely something new. I can't find a good description online of the engine mount but I'm 95% sure that where it came from.
CarGuy
New Jersey
2023 Ford Bronco
Yes, some mounts do have fluid. One of my Mercedes has these.
Ford Bronco Motor Mount Fluid? 1745844722170-bv
broadicustomworks
Hanging Rock, North Carolina
That's crazy!
On the other end of the spectrum is this low-tech option:
Ford Bronco Motor Mount Fluid? 1745846757531-s7
