- First Name
- Gary
- Joined
- Aug 18, 2024
- Threads
- 36
- Messages
- 570
- Reaction score
- 482
- Location
- Costa Mesa CA
- Vehicle(s)
- 2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
- Your Bronco Model
- Badlands
- Thread starter
- #1
It seems the factory battery in my Badlands is marginal for how I intend to use it. I have gotten suggestions which include adding another battery but I don't think I want to go that route for various reasons.
My preference is to install a battery with more CCA and capacity. I have gotten information from @Jazer on an Optima Yellow Top DH7 (Group 94R) battery that is made to fit the Bronco. It has higher CCA at 880 with capacity of 80 AH. I was concerned that it being a deep cycle battery, it would not be ideal for a daily driver. I then found out new generation vehicles work better with deep cycle batteries. So this is an upgrade and is well worth considering. It will probably have a reduced life than what I am used to with an Optima Red Top.
While I was searching for other options, I came across another brand that seems to be available only through Batteries Plus. The brand is X2Power and is also a deep cycle AGM battery but is BCI Group 27F. The size is about the same as the DH7 but it is about 1.25" taller. It has 930 CCA and capacity of 92 AH. That is even better to my liking. It appears to be able to fit in my Bronco but the terminals may not fit. The Optima has DIN-Type A1 and the X2Power has SAE Terminals. I am guessing the Bronco has the DIN terminals because the Optima is supposed to be and exact replacement for the OEM but with more CCA. The DIN terminals are supposed to smaller in diameter and taller than the SAE terminals. So, the Bronco connectors may not fit the X2Power battery. I guess I will just have to go look at the X2Power battery to be sure.
The X2Power battery has good reviews and has a 4 year free replacement warranty and appears to made in the USA. I could not find the warranty on the Optima but it is probably less than 4 years free. The Optima also appears to be made in Mexico.
Odyssey also has a BCI Group 94R battery but it has less CCA than the Optima DH7. Any suggestions on other AGM batteries that may be better?
I have not been able to find out what the Motorcraft replacement has for type of terminal. Does anyone know for sure what type of terminal the Bronco has?
