- Dec 16, 2023
- 48
- 800
- 1,491
- Washington DC
- 24 OBX, 20 GLS 450, 14 VW Tiquan
- Outer Banks
It's weird to say, and first time in probably 25 years that I used it, but I put in 87 octane instead of the premium 93 octane recently (Costco / Top Tier), and I have to say....I like it better! I know.....it's weird to say, and I'm sure many will disagree (with good reason), but I have found that the car is a little less "bucky" on the accelerator with the 87. Mine is the 4.27 rear end, and the tires are 65 series (275) SL rated, so pretty light. I've normally driven in Eco Mode just to calm it down a little bit. Decided to give 87 a try since the engine is able to handle it. I definitely notice the difference, which is not bad when the intent was to make the throttle response a little less twitchy. I'm back to "normal" mode and it drives perfect for me. The 2.7 has more than plenty of torque in general. The car definitely does not feel "sluggish" by any means. So if you're like me, give 87 a try. You may like it a little better. With the dual port injection system, carbon is not a concern, and a can of fuel treatment will actually do some good to keep the valves clean.
