Kicker Key 200.4 Done Correctly
Cordycord
Cord
SoCal
2016 Pilot, 2016 E300, 2005 MSM, 2001 B3500, 2010 Range Rover Sport, 2022 Pilot
except for bi-amp and time delay right?
the timing correction is great. HU has to have its turned off of course.
sounds like you just need to play with the gains a little bit
If the toggle switches are white, that means BI-AMP on is in the down position, right?
In other words, the picture below is showing all toggles are down.
I wanted "ALL DOWN" except for 60Hz setting to be my baseline. I was planning on turning on compression based on the clipping, and I could turn on time delay as well.
Correct?
Ford Bronco Kicker Key 200.4 Done Correctly 200_4-png-3652696164
P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
Correct?
Yup. You should have Down, Down, Down, Down, Up, Up, Down, Up.
Seth
Houston
2024 Bronco Wildtrak 2015 Explorer Sport
Tell me someone with all the above knowledge is in Houston to help me get dialed in? I'm about to drop some paper on a complete system, and I want to make sure I'm not leaving any sound on the table - and I have zero knowledge regarding settings / installation - any Bronco brothers in Houston?
P_Baff
Pierre
@AZCoyote
Did you do any ForScan mods? I'm considering changing the speaker configuration settings for the rear pods to "Speaker & Tweeter" while also turning off the factory EQ. Front sound stage is already awesome, just trying to get the best since I received the OBDLink EX cable in the mail recently.
What are your thoughts? Thanks in advance!
AZCoyote
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
@AZCoyote
Turned off factory EQ I believe. I have stock rear pods so left those as it. I set position off in head unit. Still loving the outcome too.
P_Baff
Pierre
Same, my rear pods are stock. I'm going to turn the EQ off and give the rear pods full range as a "Speaker & Tweeter" as from the factory they are only configured as tweeters I believe, and then use the HU to offset the front and rear fade like you. I'll report back with the results.
2BRONCO1
Hamilton, Ontario Canada
2011 F150
I have a 2021 Bronco, been running the Kicker 200.4 and a plug and play harness since vehicle was new. I thought the poor performance from the amp was due to a cheap chinese made amp. Finally got around to making the changes you suggested. Cannot believe the difference, sound stage is wayyy better, clear, and no distortion anymore all the way up the volume knob! All done with the cost of some wire and sound deadening. Thanks AZ for posting!
Pmharris423
Preston
Roswell, GA
Ford Bronco 4Dr Badlands Non-SAS
Very happy to find this thread as I’m about to start on my own upgrade.
I’m planning on doing this, but I have a caveat that I wanted to run by y’all. I have the kit 19-1 that includes a subwoofer signal cable, I don’t have it yet but I assume it will be tapped into the AMP1 line that is going to become my 4” dash speaker signal. Should I plan on removing the sub line from the AMP1 signal and attaching it to the new kick speakers on AMP2 signal? Key500.1 for the sub
I have 2025 with the factory digital sub signal and my new enclosure won’t have room for the factory amp, so I plan to delete it rather than tap that signal.
