Kicker Key 200.4 Done Correctly
Seth
Houston
2024 Bronco Wildtrak 2015 Explorer Sport
Tell me someone with all the above knowledge is in Houston to help me get dialed in? I'm about to drop some paper on a complete system, and I want to make sure I'm not leaving any sound on the table - and I have zero knowledge regarding settings / installation - any Bronco brothers in Houston?
P_Baff
Pierre
'12 VW GTI & '21 Ford Bronco
@AZCoyote
Did you do any ForScan mods? I'm considering changing the speaker configuration settings for the rear pods to "Speaker & Tweeter" while also turning off the factory EQ. Front sound stage is already awesome, just trying to get the best since I received the OBDLink EX cable in the mail recently.
What are your thoughts? Thanks in advance!
AZCoyote
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
@AZCoyote
Turned off factory EQ I believe. I have stock rear pods so left those as it. I set position off in head unit. Still loving the outcome too.
P_Baff
Pierre
Same, my rear pods are stock. I'm going to turn the EQ off and give the rear pods full range as a "Speaker & Tweeter" as from the factory they are only configured as tweeters I believe, and then use the HU to offset the front and rear fade like you. I'll report back with the results.
2BRONCO1
Hamilton, Ontario Canada
2011 F150
I have a 2021 Bronco, been running the Kicker 200.4 and a plug and play harness since vehicle was new. I thought the poor performance from the amp was due to a cheap chinese made amp. Finally got around to making the changes you suggested. Cannot believe the difference, sound stage is wayyy better, clear, and no distortion anymore all the way up the volume knob! All done with the cost of some wire and sound deadening. Thanks AZ for posting!
Pmharris423
Preston
Roswell, GA
Ford Bronco 4Dr Badlands Non-SAS
Very happy to find this thread as I’m about to start on my own upgrade.
I’m planning on doing this, but I have a caveat that I wanted to run by y’all. I have the kit 19-1 that includes a subwoofer signal cable, I don’t have it yet but I assume it will be tapped into the AMP1 line that is going to become my 4” dash speaker signal. Should I plan on removing the sub line from the AMP1 signal and attaching it to the new kick speakers on AMP2 signal? Key500.1 for the sub
I have 2025 with the factory digital sub signal and my new enclosure won’t have room for the factory amp, so I plan to delete it rather than tap that signal.
AZCoyote
AZCoyote
Wiley
Phoenix
i don’t know the kit 19-1 part but you only need a single input pair to the Key 200.4 to run bi-amp. It splits the signal internally to feed both AMP1 and AMP2. If your 19-1 part has a sub line, it will still go to your sub amp. All good there. The front pair off your part should feed the Key 200. All good there.
The question will be how your rear pods are powered. I had to rewire my harness to return the rears back to normal power from the head unit.
do you have a link to the part?
Pmharris423
Preston
Roswell, GA
It is the Plugnplaykits 19-1 that Ragnarkon used in his install. Here is a picture showing the signal wire running to the amp in the back
Edit: After looking at your picture on page 7 #99 I see these are in addition to what you have on the plug, and I shouldn't have any difference than your setup.
Ford Bronco Kicker Key 200.4 Done Correctly IMG_0179
AZCoyote
AZCoyote
Wiley
Phoenix
Awesome. Be sure to note post #101. You want a remote power wire from the 200 to the 500. It’s the only dependable way to turn on/off. Without it there are thumps and late signal detections.
Pmharris423
Preston
Roswell, GA
Thanks for this advice, I did, was easy enough to run along the signal cable.
I haven’t been able to run the auto-eq unfortunately. Everytime I start it I get a sad beep followed by 2 beeps right after. I think it has to do with the subwoofer. I disconnected the power to it and got no sound out of the front at all, then disconnected the signal lines and get front speaker sound but I think this is tripping the low voltage alert at the sub amp, should I leave the subwoofer on and try the eq or would it work to just run a small loop of cable connecting the positive and negative terminal for signal output on the 500.1 so it thinks something is present?
edit: the subwoofer is almost nonexistent with the remote control turned down all the way.
Another edit: I tried disconnecting the remote line and running a dummy loop on the sub amp and neither changed my outcome.
On page 9 #135 I think, someone mentions needing to complete the loop where the old kick panels plugged in, I haven’t done that, I just taped up the ends and wrapped them away, could that be my issue? Stock wiring to the dash. New wiring to the kicks
yep, dash speakers have nothing, I’ll order the metra’s
AZCoyote
AZCoyote
Wiley
Phoenix
i used the old wires to the dash and ran new wires to the kick panels. The 200 handles all that. My amps are on separate power wires so removing the fuse for sub handles that. Balance should be full front when doing auto EQ and DSP setup.
Pmharris423
Preston
Roswell, GA
What did you do with the old kick panel connections? Right now mine are empty and I’ve got no output to the dash. I’ve order some connectors and will loop them to continue the signal up to the dash. Kick panels are on my own wires like you outline. I’m assuming the pnp harness I have is tapping kick outputs so when I remove it, it interrupts the signal. I’ll try again tomorrow once I have the OEM kick connections looped
AZCoyote
AZCoyote
Wiley
Phoenix
Have you modified your harness at all?
I disconnected my stock wires at kick and taped them up. I still get sound to dash.
I disconnect everything except the front floor speakers. Troubleshoot that. Then connect up the sub and go from there.
Pmharris423
Preston
Roswell, GA
I’ve got the harness modified like you’ve laid out, I’m getting stock HU sound from the rear pods. I changed the dash speakers before I had attempted any of this and they were working before. On Pg 9 #135 he says he installed connectors that looped and it restored signal to the dash.
I forgot to post this reply yesterday, but I was able to restore the dash speakers with the connectors. Still no bi amp mode. I was able to tune it without bi amp mode but there’s an obvious need for bass blockers in the dash now. At this point I feel like it has to be the subwoofer signal line. It’s the key difference I seem to have from the rest of y’all’s plug n play harnesses. With the subwoofer amp disconnected I have to use DC or I won’t get the 200.4 to turn on. With the 500.1 on and hooked up the 200.4 turns on with 12V signal.
Is my only solution to get bi amp to get another harness without the subwoofer signal line and tap my factory subwoofer amp output? (2025 with A2B sub amp)
edit: I figured it out, I’m certainly not proud of this, but instead of wiring my kick connectors positive to positive I completed both. Miraculously didn’t fry anything, corrected and I got bi amp mode to work, sounds amazing!
Mr Nick
Nick
Chicagoland
2026 OBX SAS, 1969 Olds Cutlass
Great thread.
I have previous experience with a Kicker Key200.4, in a 2022 GMC Canyon (non-Bose) running bi-amp in front with Kicker 2.75 "tweeters" and factory door speakers. I was very impressed with how it sounded. Had a harness made with unterminated wires for the tweeters which I extended as needed.
That said, can I still expect a noticeable improvement if I install a Key200.4 in my 2026 Bronco with B&O? Are you guys and gals installing it under the dash? This would make running new wires easier.
I recently installed Infinity Reference 4" speakers in the dash and was disappointed in how they sounded. I have since removed them while I pursue other affordable upgrades.
