Issue with software updates - "getting the latest software update status"....
LS2GTO
Gene
Tennessee
05 gto 00 f-250 03 t-bird 70 chevelle 59 tr-3..
Hi folks,
Appealing here for help since a trip to the dealer was a waste of time....
I took my '23 Base, which is driven sparingly, to the dealer for an appointment last Wednesday. The issues were that the auto stop/start was not functioning, and when going to software updates on the screen I get the following message which never resolves - it just stays that way until I back out of the screen. I left very explicit notes detailing both issues with the vehicle.
With regard to the auto stop/start, I figured it was probably just a case of a low battery charge, or failing battery.
When I went to pick up the Bronco this afternoon, I was told that the battery charge was low, it was recharged over the weekend, and all was well.... I pulled out of the service bay, stopped, and checked the software update screen and sure enough, it was doing the same thing as before, as depicted in the attached image. The service advisor told me to come home and try again hooked up to wi-fi, which I did, and still get the same thing. I have been scheduled for another service appointment next week. Ugh.
Has anyone had experience seeing this screen that will not resolve and if so, what was the ultimate fix?
Thanks for any help.
Ford Bronco Issue with software updates - "getting the latest software update status".... bronco_screen
That's a new one for me. Watching
May be worth pulling the battery cable for a few minutes to let everything clear and reboot, see if that changes anything.
LS2GTO
Gene
Tennessee
So I just ran to the store. Guess what? No auto stop/start. I guess I have a failing battery. Five days at the dealership and absolutely nothing was accomplished.
Dreamer
Kevin
Connecticut
Ford Mustang GT convertible
Very timely post. . Starting this week, my vehicle says the auto start stop is not working due to battery charging. I charged the AGM battery using a charger overnight. Still getting the same error message. ASS not working due to charging. Wonder if they did something with the last Update that caused this problem. Either that or I have a bad battery or…. something else.
Will be calling the dealer to make an appointment . Good luck.
Ducati1098
While it certainly could be the battery, there’s lots of reasons why auto start stop may not be working. The instrument cluster will tell you the reason it isn’t working if you go through the menu to the right spot
Kesker
Kesker
New York
2024 Bronco Badlands
I experienced this before on a high end German car! I basically drove 5 miles a day, after a year towed to the dealer twice. Third time it happen I asked the mechanic directly WTF! He basically stated you need to drive the car. You’re not driving it enough! Now have 2024 Badlands for 6 months with 7k miles not an issue driving to trails! My advice enjoy your Bronco
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
This is 100% the fix for the screen getting hung up on the "checking for updates" screen. Disconnect the negative battery cable for 20 minutes, reconnect it and check again and it will eventually say "up to date" or reflect the info of the last OTA the vehicle received.
With FORScan, you can try rebooting the GWM and TCU, but even pulling the fuses for these modules directly has shown to not resolve the issue. A 20 minute battery pull is the more sure-fire way to fix it.
LS2GTO
Gene
Tennessee
Hi folks,
Appreciate the comments and moral support.
So here's an update.
I called Ford customer support today and asked to speak to someone regarding my hunch that the software is not updating due to the screen getting hung up in settings/software updates.
I was connected with a very nice young lady in technical support. I explained the issue, and also told her that auto stop/start was not working, and that the vehicle had just left the shop for these issues yesterday afternoon.
She was able to look at my vehicle's information online and relay to me that my last OTA software update was in December. Since that time, a new update has attempted to load twice unsuccessfully. She was also able to tell me that the state of charge of my battery at the time of our conversation was 75% (it was 100% yesterday when I left the dealership - it had just been removed from the trickle charger)....
Most importantly, she informed me that the software will not update if the state of battery charge is less than 90%.
So, five days in the shop, scheduled to return next week, same issues with no resolution or information provided by dealership, and some digging on my part with the help of Ford customer support.
The very first time that the auto stop/start failed to operate, my immediate reaction was "the battery is dying". While the issue could indeed lie elsewhere, my bet is still on the battery.
rugedraw
Javier
Miami, FL
Which update failed to install and what was the reason it failed?
LS2GTO
Gene
Tennessee
Don’t know which update; since both failures were in Jan and my stop/start issues have been going on for a few weeks, I’m assuming it failed because the battery was not at 90%.
I have heard of auto updates not happening because of low battery, just havent seen your particular error message before. Keeping it on a trickle charger over night can usually solve that.
Often the battery will work itself out after a solid overnight charge … but yeah, there is a chance it does not and you need a new battery.
Also - odd about the 90% thing, because Forscan has a setting for target battery charge level and its set from the factory at 80%…
rugedraw
Javier
Miami, FL
Only updates that require the vehicle to be parked can fail due to battery issues. Send me the VIN and I can check. The truck getting stuck on that screen is an indicator the GWM is hung up in a funky state and that can cause issues if another OTA gets sent to you in terms of it being able to install. I still recommend you pull the negative battery cable as suggested.
Astronaut
New Mexico
2017 RAM Longhorn Limited, 2024 Ford Bronco
I wonder if maybe the alternator is not charging the battery properly???
LS2GTO
Gene
Tennessee
Thanks…. I’ll send you my VIN tomorrow.
rugedraw
Javier
Miami, FL
Got your message. OTA dashboard is below. TCU update 10.1.1 is in your queue right now for the third time. Both times it failed previously, it failed because your truck did not ping the server back to accept the OTA trigger, and so far, it is not pinging the server back for this try either since it was sent to you 3 days ago.
This could very well be due to your GWM being hung up in a funky state, and the fact that when you check for updates, it cannot get past that screen you posted indicates that a battery pull is indeed needed to reset everything. While I cannot guarantee that the battery pull will 100% work to get this update to go through, I can tell you this behavior is not normal and it won't hurt to try.
The TCU is one of several modules which gets updated while the vehicle is turned on and running, so this is not a battery issue. When an OTA fails due to low SoC, this screen below will clearly tell you that is the reason.
Ford Bronco Issue with software updates - "getting the latest software update status".... 1738778462086-1h
