Include the spare in tire rotation?
Do you include the spare when rotating tires on Bronco?
  • I only rotate four tires.
    Votes: 35 19.1%
  • I include the spare and rotate five tires.
    Votes: 148 80.9%
  • Total voters
    183
amazingjason
Jason
CA
1987 Samurai, 1966 442
Do you rotate four tires or include the spare and do a five tire rotation on the Bronco?
Jason
Jawaburger
Champaign, IL
2022 Bronco, 2 Door, Manual, Cactus Gray
Unless you put so many miles on your tires that they need to be replaced in a few years, your spare tire, if left unrotated, will quite possibly still need to be replaced with the other four due to age even if there is zero wear.
Fly
MA
Subaru Outback
I rotate all 5. It is a good way to ensure the spare is in good condition (inflated, no punctures) in the event you need it.
Just make sure to eat your Wheaties before getting that last tire rotated onto the spare carrier :ROFLMAO: #squatchproblems
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Always. Why leave a tire to dry rot on the tire carrier? You will also get more tire life by adding the spare into the rotation since you are wearing 5 tires versus 4.
sfs1963
South Mississippi
88 Ferrari 328, 24 Bronco 2 door, 22 Toyota Camry TRD
I just went through this during my first service. Be aware your spare does not have a TPS. Hope it helps.
Bellime
Keith
2022 Ford Bronco
I scribe a number on each rim to track them easily.
toymaster
Leonardo
Wyoming
2023 Badlands
I'm sorry sir, that is in correct. All 5 have sensors and the bronco has a smart system, so no need to 're-learn' tire location. It does it all on its own.
Jawaburger
Champaign, IL
All 5 of my wheels have TPS in them, I have done the 5 tire rotation 3 times now and they definitely all have the sensors.
JaceHarp
Jason
Montana
2022 F-350, 2021 FE 4DR, 22 Gladiator Rubicon
I would rather have a new, clean tire on the back for a spare and trade it in when the time comes for new tires.
sfs1963
South Mississippi
I guess the service advisor was full of sh!t. My apologies and good to know for the future. Thx.
Tricky Mike
21 Bronco
I rotate all 5, with 1 exception. My set of 37s is 4 + a used mismatched 5th, so it doesn't get mixed in.
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
Just got mine done at the dealership and basically straight out of the manual, service tech said they only rotate four due to the spare never being used and a different diameter than the other four, and to just use the spare in case of flats
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Every 5k miles oil change and 5-tire rotation. Currently 42k miles and these General Grabbers still have a great amount of tread on them. When these 32's wear out I'm moving up to 35's.
