How to remove hood scoop
broncan
joey
moncton
OBX
I recently bought myself a 2022 bronco and has a hood scoop on it, I don’t know how it was installed and what products was used, anyone ever take one off ? I don’t want to damage the paint obviously…
Ducati1098
If it’s just the accessory “hood scoop” that Ford sells, it’s simply held on by double sided tape.
broncan
broncan
joey
moncton
OBX
I saw that there’s a possibility of abs glue also… on the ones they sell on Amazon.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Pictures would help. But if it is just the faux hood scoop to add +5HP, then you can remove it as it is held in place by double-sided tape. Take a heat gun and warm up the perimeter and remove it. There will likely be some residue.
VirginiaHeritage
Frank
‘25 Bronco HE
A heat gun is essential but use the lower heat setting and keep it moving. Don’t hold it too close or in one spot for too long. Plastic razor blades can be helpful too, to get under the tape edge and get the peel-off started.
GI_Jo_Nathan
Jonathan
Another thing you can do after you heat it up is run fishing line or some sort of cord around it. It can cut through the double-sided tape. Of course then you still have to deal with getting the tape off.
VehicleNanny
Bill
vehiclenanny.com
2025 Bronco Big Bend + 2014 MINI Countryman
I just got my Bronco, but I added and removed a lot of 3D printed trim on the hood of my Ranger. I got pretty good at removing those items (including fake hood scoops) using fishing line, heat gun and adhesive remover. A was said earlier, take great care with the heat gun. I use it only if the double sided tape is being really stubborn. Don't use it to loosen the tape from the hood scoop as you will deform it.
I wrote up my process for removing trim and badges...hope this helps!
Safe Removal of Badges, Emblems and Moldings
helifino16
Ron
Mount Sinai, NY (Long Island)
Sounds like these... They're supposed to boost the HP as well:
Ford Bronco How to remove hood scoop 1769189642273-o7
broncan
broncan
joey
moncton
OBX
Just an update , I finally removed it …. It was 2 sided tape x2 and windshield glue! It took 2 hours with a plastic blade , patience and 3m adhesive remover. But it’s off
