HOSS 3.0 Lift options?
Shifts And Grins Fab
Ryan
Gilbert AZ
shiftsandgrinsfabrication.com
2023 Badlands, 2022 Bronco Wildtrak Sas
The HOSS 3.0 Fox’s are soft in the rear… It squatted a lot for me on acceleration in Sport and would even bottom out hitting it hard, especially after adding LOD rear bumper/tire carrier. This in-turn impacts cornering/leaning in turns as well. Add any weight whatsoever and it floats around like an old Cadillac and you’re constantly riding in the stiffer part of the progressive spring.
Adjustable coilovers are the best option. My ADS fixed the squat and made it more planted, but I can adjust that feel too. I can easily adjust height and compression on my ADS for a more level or raked look, as well as increase the compression for added weight or more spirited off-roading. This works great for camping trips where I’m loading up 300-400 lbs of gear and I can just bump up the rear 5-6 clicks. Yet, I still get amazing flex.
However, if you’re not needing that level of performance, I‘ve read a spacer in rear and spring perch in front is best. You need to keep the geometry the same in the front via the perches, or with a small spacer/perch combo like the new Zone I believe does So you don’t exceed the allowable droop. Then the rear can handle the spacer and get you extra travel, it can handle the droop. But, you can’t just add a spacer in rear, that will cause a ton of rake and throw off the handling. Perches in the rear are fine too, but don’t gain you anything and with either of these you’re messing with the “sweet spot” Of the Fox’s. Eibach was coming out with HD springs, but I believe they also lift, and Dobinson had some heavier springs that were supposed to work, but I think they also lifted. Might check them out.
A lot of people say they can’t feel a difference in ride with the spring perches, and maybe their butt-o-meter is different than mine… However, given the progressive rates and how sensitive they are in their tuning, I didn’t see how I wouldn’t notice given what I experienced with the added armor weight. You’re going to be out of their “sweet spot”.
Even with playing with the coil over height and compression on my ADS, I can tell a difference in how the Bronco steers and handles. It handles best with at least a little rake given how Ford designed it, at least to me, and I run mine with only .25-.5 rake, but I can tune this at anytime with my setup…
You can't go wrong with an ADS Suspension setup on these. Especially since we take the time to get you build specs and weights and make sure you get the right spring rates out of the box the first time.
https://shiftsandgrinsfabrication.com/product/productads-arizona-desert-shocks-bronco1296/
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
Ryan
Gilbert AZ
I really need to look into these. I find myself taking out the Jeep with my group far more than the Bronco.
Yes you do. Let us know when you are ready to chat. I've had several Jeeps that I have built over the years. My Bronco does everything any of my Jeeps have done but with more comfort. I loved my Jeeps. Not a Jeep hater at all. I still love Jeeps. I bought my Bronco as a filler vehicle but the more I build it, the more I realize it is the most comfortable and capable vehicle I have owned. It checks all of the boxes so I have kept it longer than I expected and have no plans of getting rid of it any time soon.
hold24
Bobby
Canton Ga
2020 Ford F250 limited
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
Heckler
Larry
San Mateo
2023 Bronco
Can someone take a picture of the bottom side of one of the spacers, I’m curious if they have corrected the orientation of recesses where the bolt head goes in, I’ve seen pictures of them split because they had one of the hex points to the outside causing it to have very little material between the hex and the outer portion of the spacer.
My kit is sitting in my garage, interested to see the results of yours!
aspen71
Ryan
Northern California
2023 Bronco Wildtrak
I have a bad case of "decision fatigue" now for lifting my 23 Wildtrak... I'm configuring it for higher speed desert use, but don't necessarily want to abandon the Fox internal bypass shocks that I paid for as part of the Hoss 3.0 setup. I was all in on the Eibach springs , and then the Zone 2.25 setup, but also the RC lift seems interesting too.
In terms of the RC lift, isn't it really a spacer lift? My concern is issues with full extension and decreased travel... or does the RC kit somehow eliminate that concern? Also, do you get a true 2.5 inches and enough to run 37's at full flex? Genuinely curious on how to get more clearance without dropping $6K on aftermarket coilovers and there seems to be no real good options.
And for what it's worth, I will eventually invest in a coilover system like ADS, Fox or King; it's just hard to justify right now. I know it's the correct way in the long term, but I need to reign in my spending for now.
Nanook
Jonathan
All of them will need a max tire clearance kit to run 37’s.
I Considered Eibach springs but not a lot of lift provided and I’m not weighed down to justify the rougher ride.
Body lift is a great option but I had too much trouble finding someone who could fabricate some bumper relocation brackets.
I went with Zones 2.25 kit due to their affiliation with Fox and I didn’t want to replace the stock Fox shocks. 🤞
aspen71
Ryan
Northern California
Yeah, I keep coming back to that too if for no other reason it draws a balance between the spacer versus perch collar argument. I did call Zone and it turns out they'll sell the kit itself for just over $200 without their UCA's so I might do that and order the Icon UCA's to at least be done with that for when I upgrade to a coilover setup over the next year or two. 🤷‍♂️
SixEighty680
2dr BadSquatch, 22 Indian Chieftain
Ryan
Gilbert AZ
Buy once cry once. Can't beat ADS especially in go fast. Let me know if we can help or answer any questions. We have had several customers purchase an ADS kit from us and ditch (sell) the fox shocks to recoup some of the cost. Every one of those customers has been super pleased.
Here is our Ford Bronco Kit from ADS
adamruiz2001
SoCal
Ford SVT Lightning
mattymik
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Do you have pictures?
I forgot to come back!
BEFORE
Ford Bronco HOSS 3.0 Lift options? output_image1712587289480
Ford Bronco HOSS 3.0 Lift options? output_image1712587316034
AFTER:
Ford Bronco HOSS 3.0 Lift options? output_image1712681805286
Ford Bronco HOSS 3.0 Lift options? output_image1712681820404
IMPRESSIONS
* Ride a little firmer, but no less comfortable.
* You feel bumps a *tiny* bit more.
* Brake dive noticeably reduced
* I can’t comment about articulation or travel, but at high speed offroad, the shocks still respond great.
* Ride height just looks better and totally level
* I would recommend this, especially if you want 37s (which I’ll do soon)
MEASUREMENTS (to bottom of flare)
Before, Rear: 39.5”
Before, front: 38.5”
After, Rear: 41” (+1.5”)
After, Front: 41” (+2.5”)
RobWTX
IMPRESSIONS
Before, Rear: 39.5”
The kit is pretty darn good, isn't it! Had mine on about 2 weeks I think, nothing but mall crawling so far, but the ride is like you mentioned, not a lot of difference to me so far.
Only difference I have, my front is 41 inches, rear 40, with the standard setup the kit had. Looking at ways to address that. I actually like the normal rake, I am in a small crowd that way, lol.
