HELP!!! Snapped a bolt
Robs94Bronco
Orange County
2023 Bronco Badlands Sasquatch 2.7L, 1994 Bronco Eddie Bauer 5.8L
I snapped a guide pin bolt on my rear caliper and ford says they don’t sell them and I have to buy the whole assembly. Anyone know where I can just get a new guide pin and bolt? Is the front the same as the rear cuz they sell a front guide pin kit.
How about a picture of the damage?
Rush4th
Donny
Norco, ca
2021 bronco
I’ll check rockauto, but the fronts are different than the rears and the only kits like that I found like that were for the front. 15mm front, 13mm rear.
Ford Bronco HELP!!! Snapped a bolt IMG_8180
got it out though..
Ford Bronco HELP!!! Snapped a bolt IMG_8181
Rush4th
Donny
Norco, ca
2021 bronco
Well rockauto is a no go..
Ford Bronco HELP!!! Snapped a bolt IMG_8191
This one is the California compliant one.. out of stock and no eta..
Ford Bronco HELP!!! Snapped a bolt IMG_8193
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
You could just buy a set of pads..........
Ford Bronco HELP!!! Snapped a bolt 1770706300715-g1
JP2
SoCal
Bronco 4 door
BoltDepot.com is my favorite
GI_Jo_Nathan
Jonathan
Interesting. My pads didn't come with new bolts. Assumed OP was doing pads.
Rush4th
Donny
Norco, ca
2021 bronco
Ended up going to a hardware store and picked up some new ones. Ford did confirm that OEM rear brake pads come with new bolts, but $130. I shoulda went OEM.
They don’t sell bolts or pins by themselves for the rear. If you want pins, you need a new caliper bracket, which the dealership sells for $180. They sell a pin and bolt kit for the front only. Super lame ford!
I was doing new pads, I went off the 48 lbs per ft like I did the first time I changed them. Never realized it was only 22. oops, a fun mistake.
