Stripped Beauty Ring Bolts...HELP!
greatlakes
Grand Rapids
67 Buick Special
I sprayed all of mine with Liquid Wrench before removing them. It seems to help.
RHeinz
Ric
Houston, TX
Thank you for the help guys! I will see what I can do. Wish me luck.
The first thing I would try is using the proper Torx + bit. Take the wheel off the vehicle and lay it on the ground so that your working from above it. Put extreme pressure downward on the bit. If you can turn the screw I would gently work it back and forth to avoid galling each time going in the loose direction slightly more. Thread lubricant may also help.
RHeinz
Ric
Houston, TX
jar1229
jar1229
Detroit
2022 Ford Bronco Base 4 Door
What a mess lol. As other threads say to use the PLUS and not the straight T45. SMH!
BBoyM3
Robert
San Antonio, TX
2015 Toyota Corolla LE
Yes. Confusing. I only know it's T45 because it took several discussions with an ME on the forum to get the correct size.
Oldhippie
Barry
Santa Cruz, Calif.
Weld a nut to the bolt and use a wrench
