Beauty Ring Bolts
VictoryLights
Pittsburgh
2018 Honda Pilot
iamchewby
Chewby
When I did custom work we would get all of our nice bolts at Fastenal. They're a national chain so I'm sure you probably have one near you, they're always really helpful when trying to find something.
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
Thank you. Does anyone know what type of bolts they are? I’m not an expert.
GToddC5
Todd
South Jersey
www.bronco6g.com
Most likely socket button head. This place is where I order fancy hardware:
https://www.boltdepot.com/Metric_socket_button_head_Chrome_plated_steel_10mm_x_1.5mm.aspx
Another member was kind enough to share this link with me:
Not trying to hijack this but we installed rings on a new unit and had to drill 6 of the mother f'ers out due to round off. Couple things we've noticed. One, the socket isn't deep enough for a Torx. Two, the major problem these are difficult to extract is because of the yellow Loc-Tite applied to the bolt from the factory. Three, steel bolt, aluminum ring, aluminum wheel, frequent exposure to water, road salts and chemicals. Tell me, metallurgists, what do you think is going to happen in 6 months when you want to take them off?
I'm trying to find aftermarket replacements since $12.00/ea, 12 per wheel, isn't going to cut it. Button head, M 10X1.5X25. Head is 16.3mm wide and just under 5mm high. The recess in the ring is approx. 17mm wide so the standard bolts I've seen that are 17-17.5mm wide, aren't going to work. These really need to be some flavor of stainless that can be coated/plated black. Ready, set, go!
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
Stripes136
North Florida
youtube.com
2022 Ford Bronco
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
Can you let us know if this worked? I am thinking the stainless steel will breakup the all black ring and black rim. Thanks
Yes. I should be getting my black rings any day now. I was planning on choosing between black and stainless steel bolts once I get them.
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
The bolts are custom made for Ford. Very unlikely that you will find an exact match off the shelf. You may find something that is close enough and works, but you won't find the exact Ford part.
VictoryLights
VictoryLights
Pittsburgh
2018 Honda Pilot
I trust that you are an expert on this topic of silver bolts :LOL:
Vinny6G
