Help- can't remove front lower control arm cam bolts
Shelhart2
Shel
Orlando, fl
2022 bronco black diamond
I can’t seem to get them out. Installing leveling kit and got nuts off but seem to be stuck. They just slide out, correct?
‘21OBX
90Bronco19
2022 bronco outer banks
They do but you have to remove the load from them. If Your up on Jack stands take your Jack and gently relieve the pressure from the arm. Mark the cams for reference.
Shelhart2
Shelhart2
Shel
Orlando, fl
Thank you. My markings were erased by extensive work to get them off😁. Sure not going to be aligned after done. Best to eyeball it and take for alignment. Torque specs on these bolts.
BigMeatsBronco
Allan
2021 FE 2 door
Yes be sure torque is correct when reinstalled. Very important here
‘21OBX
90Bronco19
Your alignment would not be correct even if you went back to your marks but would be close. Anything that changes the height/angle will throw the alignment out.
Shelhart2
Shelhart2
Shel
Orlando, fl
Yes. Do I need to turn the cam washer separate from bolt to get off? I see grove in bolt. Having heck of time getting bolt out. Cam washer on nut end stuck to bolt. What am I missing? Sorry for noob questions.
Ford Bronco Help- can't remove front lower control arm cam bolts D84E0995-A97C-4047-9C49-B0E25BC34865
Ford Bronco Help- can't remove front lower control arm cam bolts BFC23EEF-0395-4B41-B212-6F57E9E8C449
Ford Bronco Help- can't remove front lower control arm cam bolts 5F494751-9341-43C1-B32D-725DA05F0118
BigMeatsBronco
Allan
2021 FE 2 door
The washer on the bolt side is attached....the one on the nut side is removable.
Shelhart2
Shelhart2
Shel
Orlando, fl
Makes sense. Shouldn’t the cam washer come off freely and bolt tap out? I’ve removed tension on arm and still seems immovable.
Robbie_S
2022 Bronco OB Cactus Gray
Not sure if you figured this out but after disecting ours last night for our RC lift it appears your cam washer has twisted on the bolt?
GreyZ
Gulf South Louisiana
I second this. If this is the case, you will need a hammer and a new set of cam bolts and washers. This can be caused by trying to loosen the bolt instead of loosening the nut.
0ne
Nate
CO
Flex
No offense but maybe get it back together safely and have a good shop do it? Important components down there and a forum is not the best contingency plan.
Shelhart2
Shelhart2
Shel
Orlando, fl
Yes, it’s now clear. I didn’t remove via the nut side and, therefore, torqued the cam washer onto bolt pinning washer to frame. Not fun to remove. Note to others…. Put a wrench on bolt side and don’t allow to move and use impact on nut side and bolt slides out without issue. Very simple and kicking myself for such a no brainer. I have all new hardware. Other side was done in an hour and even installed revised crash bars. I look brilliant on other side of car😁
dgorsett
colorado
F250, Mustang, Explorer
Every job is a learning experience!
NateTTU
Nate
Fort Worth, TX
2025 Bronco
First time coilover replacement here and it's been a pain for sure. I broke these small tabs off next to the lower control arm bolts. Looks like they were to help prevent the cam washer from spinning. I don't think it's a big deal, what do you guys think?
Ford Bronco Help- can't remove front lower control arm cam bolts 1776085114640-g3
JL8jeff
Ewing, NJ
You need those tabs (pins) to help set the alignment. I would guess most alignment shops will have them but I've gotten them at NAPA before. Did it snap off or come out cleanly? If it snapped and part of the pin is still in there, that needs to come out.
