FORScan vs Flashcal+
FoCoBronc
Colorado Springs
‘26 BL - previous ‘22 OBX, Tacoma, X3, MDX, Bronco II
They appear to do almost the same thing. What are the differences and pros and cons? Is one basically a Ford product and other is not?
PWillette
Parrie
Maine
Long story short, forescan is a computer program to change settings...Flashcal+ simply does the changes w/o the need for a computer. Forescan has many more options to access but fairly cumbersome for a newbie not familiar with the procedures for changing settings.. Flashcal+ super easy to use but only a select set of options to change. Forescan also requires a subscription to access the program.
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
FORScan is very powerful and Ford-specific program with many built in service and calibration procedures that you would also find in FDRS which is the program Ford dealers use to diagnose vehicles, reprogram modules, and much more. FORScan also gives you the ability to reconfigure modules in both an easy and advanced modes to enable/disable many functions, as well as module programming capabilities for more advanced users. It is not endorsed by Ford in any way.
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
FORScan is worth learning to use.
Wyld2dr
I'm thinking they stack?
They can both be used, but FlashCal is literally doing the same thing as FORScan but without you typing in the code. It's for people who don't know how to use a computer or spreadsheet.
razehound
SoCal
2025 Bronco
One is an extensive software run on Windows that requires a subscription and being smart/careful.
The other is a boiled down version of that same software which can run on your phone and is a one time purchase. It contains only certain settings which the developer deemed as useful for the average bronco diy owner.
adcam
Mando
2025 Stroppe
It’s like Manual transmission and Automatic transmission. Forscan (MT) and Flashcal(AT).
Wyld2dr
"Subscription" - you just change the date on your computer to be inside the correct date window.
PWillette
Parrie
Maine
Does that still work?
Wyld2dr
Eldowerks
Minnesota
Bronco ‘24
Flashcal+ is for people who very well know how to use a computer and a spreadsheet, but would rather not mess around researching through arcane codes on a spreadsheet and buying a subscription, an adapter, and a buggy peecee laptop to make select changes to their Bronco.
I am really enjoying running Sport mode on my Badlands, not having the double honk when I step out of my truck with the ignition on, and not having the panic alarm going off inadvertently, all courtesy of FlashCal+ and ten minutes of my time.
PWillette
Parrie
Maine
IMO the biggest plus for Forscan is the ability to troubleshoot when out on the trail. Flashcal+ is certainly a great simple tool to make changes but virtually no way to troubleshoot.
CalvinT
Calvin
Phoenix, AZ
Forscan is free if you have a laptop and the needed adapter costs less than Flashcal.
Flashcal only makes sense to me if I wanted to also do some tuning.
ducksface
Stroppe
Grand Canyon, Arizona
2025 stroppe
Stroppe
Torque pro and an obd2 dongle.
(Unless there's some bronco thing I don't know)
