Factory Fog Light Switch
Snowdogyyz
23 Ford Bronco Wildtrak
Maybe I’m missing something here. I installed the Oracle triple fog light kit in amber. For now I used the 4x4 TRUCK LED quick connect harnesses to connect each side to the fog light switch harness near each tow hook in the front. Bought the correct factory fog light switch. Made all the changes listed here in the BdyCm, IPC and BdyCM as built (0101). The lights will not come on. The indicator lights up on the dash but I’m not getting power to the fogs. Am I missing a.step somewhere?
2023 Wildtrak with Mod bumper.
Gotchaa
Los Angeles
Tesla
Try changing it to 0303
Snowdogyyz
Snowdogyyz
I’m wondering if the harness is not connected somewhere. Going to trace it soon. Wouldn’t surprise me if that got missed at that factory,
Snowdogyyz
Reset all settings to before and then re-input them- no joy. Every time I try to load my saved profile that I saved the first time I connected to FORSCAN, it asks me about the transmission type. Not messing with that! Any idea what that’s about?
Gotchaa
Los Angeles
Tesla
Not sure, can you post all the changes you made in Forscan for the front fogs?
Snowdogyyz
I followed this post-
Ford Bronco Factory Fog Light Switch 338375AA-921E-4192-AC54-4CAC6406F7B9
Riverjeep
Va.
Wildtrak, F-150
Which string of numbers in the BdyCm are you changing to the 0101 sequence, give me the complete string please?
Snowdogyyz
Ford Bronco Factory Fog Light Switch 6392BE70-3796-4863-B593-A512A057DD08
Gotchaa
Los Angeles
Tesla
Here are all the settings for reference:
For 726-42-01: the ”0101” is for Fog Cornering, I have it set as “0303”
Fog Lamp Ckt Usage(LFRF - Left Front/Right Front): 00=Not Used 01=Fog Cornering 02=Fog DRL 03=Fog DRL Cornering 04=Fog Only 05=Power Supply
Ford Bronco Factory Fog Light Switch IMG_0263
Ford Bronco Factory Fog Light Switch IMG_0262
Snowdogyyz
I tried 0303 and that didn’t work either. Makes me wonder if the harness isn’t connected somewhere.
RFMETZ
Ryan
Lakewood, CO
GX460
I'm in a similar situation but when I tried to change from 0101 to 0303 I got an error for the auto checksum. Sorry if this is a basic Forscan question but am I doing something wrong or just continue?
Ford Bronco Factory Fog Light Switch Screenshot 2023-04-22 220114
zuke
Stafford VA
You're avatar looks like you have the Park Aid sensors in the front bumper, If they work, then you've got all the correct wiring harnesses in place, the harness runs back to C192 from the front, and from C192 back to C203, then from 203 to the connector on the actual BdyCM if you wanted to trace them out.
Snowdogyyz
So the total amp draw of these fogs is 7.5. Is that too much for the fog light switch circuit? I’ve seen folks running 6-6.5 amps with no issues. I’m going to eventually wire one light per side to the switch and two per side to aux switch 2 but didn’t have time this weekend so just plugged them in temporarily to the front harness,
BCFDLtE13
Wayne
Manchester, MD
2015 Mustang GT Performance Pack
Look at the pic from an old post. There are a few places where you need to "enable" the settings as well. I had the same issue at first.
Ford Bronco Factory Fog Light Switch Screenshot_20230120_131845_Samsung Internet
