I just received this kit from @SPVPARTS Specialty Performance Parts Baja Designs Triple Fog Kit
I ordered an SAE Clear, SAE Amber, and Driving/Combo light for the 3 pairs.
My questions:
In what positions would you mount these 3 relative to the center/edge of the bumper? I intended to use the Sae clear for better visibility to other cars in good weather and the Sae yellow in fog/snow for better vis. Idk what I will use the driving/combos for other than very occasional backroads for night driving. As such I think I might mount the SAE Ambers nearest the center, SAE clear in the middle, and driving/combo on the outboard position, but idk.
Secondly I am considering wiring the SAE clear to the stock fog lights wiring since I read that lux packages with mod bumper came with factory fog light wiring, just no lights. I realize this would require procurement of a different light switch panel for the dash and forscan to activate the switch. Do you think this would be worth it or would you just run them to an aux switch like I will do for the ambers and driving/combos? Do you know what kind of extra harness I might need to plug into the factory wiring for the fogs if I choose to go this route? Could forscan make the pair attached to the factory wiring be configured as DRL’s? I would also like to configure my tail lights as DRL’s. Thanks.
My questions:
