Baja designs pro triple fog light advice for modular bumper
LSW
L
Alaska
2024 Bronco Wildtrak, 2023 Bronco Outer Banks
I just received this kit from @SPVPARTS Specialty Performance Parts Baja Designs Triple Fog Kit
I ordered an SAE Clear, SAE Amber, and Driving/Combo light for the 3 pairs.
My questions:
In what positions would you mount these 3 relative to the center/edge of the bumper? I intended to use the Sae clear for better visibility to other cars in good weather and the Sae yellow in fog/snow for better vis. Idk what I will use the driving/combos for other than very occasional backroads for night driving. As such I think I might mount the SAE Ambers nearest the center, SAE clear in the middle, and driving/combo on the outboard position, but idk.
Secondly I am considering wiring the SAE clear to the stock fog lights wiring since I read that lux packages with mod bumper came with factory fog light wiring, just no lights. I realize this would require procurement of a different light switch panel for the dash and forscan to activate the switch. Do you think this would be worth it or would you just run them to an aux switch like I will do for the ambers and driving/combos? Do you know what kind of extra harness I might need to plug into the factory wiring for the fogs if I choose to go this route? Could forscan make the pair attached to the factory wiring be configured as DRL’s? I would also like to configure my tail lights as DRL’s. Thanks.
SPVPARTS
Lux Sponsor (Level 2)
Greenwood, IN
specialtyperformanceparts.com
Ford Raptor/Bronco/Mach E
My questions:
So really, the position that. You choose to place each is really personal preference. There are not really any functional benefits to one being in one spot or another. So if you like the yellow in between the two clear, or the yellow to the far outside. It really comes down to personal style.
As for the harness and factory fog switch. That also is personal preference. There can be some advantages one way or another, but it really just comes down to preference and the setup you are trying to achieve.
For example. If you are using all 6 switches for something. Having that fog switch as a 7th can be a benefit. However, if you don’t use all your switches. It may be just easier to have them all located in one spot on the aux switch panel. This give more complete control in one place.
Plus the work it takes to reprogram the pcm and install a new headlight switch. If you don’t use all your aux switches, it may be more hassle than benefit, but if you run out of them, it can be an advantage.
if you do want to add a fog/headlight switch and reprogram. There are plenty of posts on here showing how to.
As far as connectors, we have those here and ready to plug into that spot it you add a switch.
Does that help?
604Bronco
British Columbia
www.bronco6g.com
I have a different set of Baja Designs lights in my modular bumper, but here’s my setup if it helps? I put the amber on the “inside” spot.
Ford Bronco Baja designs pro triple fog light advice for modular bumper IMG_8928
Luckylat
RI
1999 Expedition, 2013 VW Wagon, 2023 Wildtrak
My questions:
I am assuming you are referring to the Baja Design Squadron lights. There are 3 versions: The Sport, Pro & Max. The SAE's provide you with wide cornering and I would consider having the White SAE in the outside for better visibility. The Amber SAE in the center. The Combo provides both driving & spot for distance, I would confirm if it is either a Sport or Pro model. The Pro model lumens output is significantly more vs. the Sport. I would mount these on the inside position. Because the SAE's throw a wider cornering beam place these on the outside.
As far as Aux switches: I have all three of mine on a separate Aux, using a 4th one for the yellow backlit feature all my lights have. I also have Pillar/Ditch lights and back up lights wired to my Aux switches. When wiring, I hope that you were provided with a wiring harness that makes it simple.
The OEM wiring harness can be tricky.
I went with Diode Dynamics but Baja Design is also a great option and in my opinion both DD & BD arguably provide the best quality light. Good luck and the additional lights make a BIG difference in all types of conditions. You will love them.
FYI: I sized mine lights by type, lumens and cost, but the backlit feature won me over to go with DD.
Below is my table with the light configuration and lumen output. The brighter driving light I placed on the inside as I want the wider cornering lights on the outside.
SS3 Max - White Combo
7,900​
SS3 Pro Yellow SAE Fog
3,000​
SSC2 Pro - White SAE Fog
1,988​
All Backlit
12,888​
LSW
LSW
L
Alaska
Thanks all, very helpful replies.
The B.D. driving/combo pair are Squadron Pros with the higher lumen output. I am also getting a pair of squadron pro spots that I might use as ditch lights later.
Doing some research into white SAE fogs as DRL’s is starting to make me lean toward wiring everything to the aux switches. Apparently fog drls are considered discourteous or illegal in many places. Also the fact that a 70+ page thread is needed for wiring into the fog light switch on the factory light control panel leaves me hesitant, it seems like it might not always go smoothly.
bkirchhoff
Middlebury, VT
BMW: '07 328xi, '13 X1, '75 R90/6, '12 R1200GS
FWIW I put my ambers in the middle. The large ones are actually all white (picture makes them look half amber for some reason). As others have said, it’s mostly preference. There isn’t going to be any noticeable, functional difference.
Ford Bronco Baja designs pro triple fog light advice for modular bumper IMG_2718
As for wiring, I have each set on its own aux switch. If I run out of switches, I can always combine later but I didn’t want to mess with looping them into the DRL or factory fog switches. It’s just too easy to use the upfitter wiring. Happy with the results on mine.
Enjoy! You are about to make your Bronco even better.
Mjasi3
Chicago
24 wildtrak. I did 2 sae quads and one combo driving. Wired all to aux as i didnt want to mess with control panel replacement and wiring headaches. Wired to AUX 345. Thought I miss the fig option, but I mostly just leave an AUX on. Couldn’t be happier. I got from 4x4ledlights and they provide their own harness that makes it plug and play, just have to connect the 3 AUX. very easy.
  • Like
Reactions: LSW
Luckylat
RI
Ford Bronco Baja designs pro triple fog light advice for modular bumper IMG_7181
After much research, I also worked with the team from 4x4truckLEDs. They are knowledgeable, have a wide selection of lighting options, have great wiring harnesses and hardware help with any lighting need. They are also a good group of guys to work with.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Thanks for the kind comment and business. We appreicate it.
It doesn't honestly matter as none of the lights get blocked really if you did a 2x Squadron + 1x S2 kit. If you did 3x Squadron I'd put the Driving/Combo on the outside since it'll get blocked a bit.
Then it's up to you with the SAE. Just make sure you install them right-side up, as Luckplat shows in his photo. If mounted upside down the optics will not be ideally aimed. You also cannot remove the bezel/lens and flip it since that voids the warranty with Baja Designs.
We do make a bracket for this so that you don't have to void your warranty. Again this only matters if the lights are upside down in the bumper.
https://www.4x4truckleds.com/kr-off...-baja-designs-s2-squadron-series-lights-pair/
This is the pigtail you'll want: https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
  • Like
Reactions: LSW
LSW
LSW
L
Alaska
Great, thank yoU! I'll put the Driving Combo (yeah all 3 of my pairs are 2x2) on the outside then! Ordered a few brackets from you so that the lights will be oriented correctly. For now I think I'm just going to wire it all to the factory AUX switches, since if I do want to run the fogs on all the time as DRL's I can just leave the AUX switcfh for the white SAE's on all the time. As I understand it, the Bronco will automatically power the lights that have the aux switch left on when the igntion switch comes on and will remove power when the ignition is turned off.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
That is correct. The upfitter power turns off when the truck turns off
  • Like
Reactions: LSW
LSW
LSW
L
Alaska
Here is my Baja designs triple fog kit from @SPVPARTS with the long mounting brackets from @4x4TruckLEDs.com since the modular bumper didn’t come with fogs on my ‘24. Wired each pair to aux switches 4,5,6. Amber SAE, White SAE, and squadron pro driving/combo.
The white SAE in the middle works the best in terms of beam obstruction, yellow on the inside gets diffused a little from hitting the inside of the bumper, resulting in a bit of a fuzzier top beam cutoff line. Driving/combo Baja designs squadron pro is really bright but for off road only since it’s too bright to be street legal. Probably should’ve put the yellow SAE on the outside since I’d imagine I will use it more than the driving/combo, and the outside position seems less obstructed for a wide fog beam. Adjusted the fogs to have top of beam 4” below level at 25’ for proper aiming.
Ford Bronco Baja designs pro triple fog light advice for modular bumper IMG_1848
Ford Bronco Baja designs pro triple fog light advice for modular bumper IMG_1846
Ford Bronco Baja designs pro triple fog light advice for modular bumper IMG_1849
The only issue I had is that one of the amber SAE lens cover seemed to be on at a 90 degree off position because the “SAW F 20 BD 250011” writing was on the left side of the light when viewed from the front instead of the bottom like the other 5. I rotated the Lens cover not knowing if keeping it at that angle would affect the beam pattern or not. Install was pretty straightforward, just be sure to get a weather-pack crimping tool and the tiniest hex ratchet possible with a dremel-shortened 4mm Alan key hex driver so that you can adjusted the beams’ aim after install.
I chose to run the wires more or less straight up from over the front of the driver front crash bar and behind the front part of the wheel well lining. I tried to get the fender flare off to run the wires further aft above the wheel well lining but was having difficulty and didn’t want to risk breaking off one of the plastic rotating snaps on the flare. I ran the wire straight up in front of the battery, then outboard of the battery and along the edge of the engine bay to the aux switches with half a dozen zip ties along the way.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
What do you mean your SAE light was off by 90 degrees? So you're saying instead of being level it was rotated 90 degrees and was SIDEWAYS?
I know you didn't get the lights from us but that's a bit... weird. The lense actually won't change the pattern, there are optics inside that would need to be rotated as well, but you are not supposed to be opening the lights. That's what the longer extensions you got from us are supposed to do, which you used. They hang the SAE light ride side up.
But your issue sounds like something else, as if the SAE lights were taken from some other vehicle kit that has the lights mounted SIDEWAYS.
The lights we sell are already flipped from the factory for our customers (and worse case scenario like we recommended to you, was that they'd be upside down so you use our extensions).
LSW
LSW
L
Alaska
Yeah, the lens cover on one of the yellow SAE lights, just one, had the SAE and BD etching on the left side of the cover if viewed from the front. The white “Baja Designs” logo was still on the correct spot at the top as was the interlocking BD in the middle of the light. It must’ve been just the cover because the filament inside of the lights were still vertical and the beam was definitely horizontal, not vertical, after I began aiming them. Thanks for the help, brackets worked well!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah, the lens cover on one of the yellow SAE lights, just one, had the SAE and BD etching on the left side of the cover if viewed from the front. It must’ve been just the cover because the filament inside of the lights were still vertical and the beam was definitely horizontal, not vertical, after I began aiming them. Thanks for the help, brackets worked well!
There's no covers on Squadron SAE lights though. I think you are refering to the lens itself.
Was it RIGHT SIDE UP? The text should have been right side up.
The light should look like this
Ford Bronco Baja designs pro triple fog light advice for modular bumper 1716063609760-qt
And then you'll use our longer extensions to keep it in that orientation (the kits we do, are actually opposite where the mounting points are on the TOP because we have Baja Designs flip the lenses/optics for us PRIOR to shipping us the lights, this way you don't need the extensions).
As long as the SAE portion is right side up AND you didn't have to ROTATE anything you are good. BUT if you had to rotate that because the writing was sideways or upside down, well unless you ALSO rotate the optics your light will not be installed correctly.
The lens is a spot lens, the orientation honeslty does not matter. It's the optics INSIDE that matter and have to be oriented correctly or the pattern is off. BUT doing so (by opening the light) also voids your warranty these days.
  • Like
Reactions: LSW
