Emergency Tire Patch / Repair Kits
RHeinz
Ric
Houston, TX
When in a remote location and in a bind, are these kits useful?
kodiakisland
Arkansas
Tire plugs are useful anywhere.
66Fan
Tim
IL
2022 Wildtrak
If you know how to use them prior to being in a bind, yes.
If you're trying to figure them out in a pinch, no so much.
Silver-Bolt
Eureka, MT
Only useful with a means of re-inflating the tire.
Roger123
Roger
VA Beach, VA
Plug kits are great but don't get a wimpy one from Auto-Zone, it's not easy to plug a heavy duty 33" tire. You also need to practice, trying for the first time on side of a busy road at night in the rain with no shoulder will not end well.
For me, I put the spare on and will only plug on getting the second flat (knock on wood, hasn't happened yet).
RHeinz
RHeinz
Ric
Houston, TX
OK. Thanks all for replying. Makes sense not using it until absolutely required. That’s more like what I had in mind.
Got a three day trip out to Big Bend Ranch State Park next month. Pretty remote. It seems like a fairly small (to carry along) backup for the spare.
Any specific brands to recommend?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
RHeinz
RHeinz
Ric
Houston, TX
Actually, I did not think the Flex Seal spray was all that great on metal. The Flex Seal “paint” did roll on very well however. So it works on tires too huh? Do you just spray it on the outside around the leak?
I assume you saw the TV add where they put Flex Tape on the leaking truck tire tread and stopped the air leak before the tire had to be re-inflated ? It also does a great job on steel boat hulls after sustaining torpedo damage.
Roger123
Roger
VA Beach, VA
RHeinz
RHeinz
Ric
Houston, TX
Anyone have experience using a GlueTread sidewall repair kit?
Tripodbruno
Centennial
tacoma(no more) F-250, Hiker Trailer, Jeep Rubicon
I have a set, have only tried on an old tire wheel not under load. You need to carry windex/alcohol/water to clean the area well prior to application. I would use with a plug if possible. I have always used plugs for tread/puncture flats. Keep in mind they are not DOT. So the patches are more for getting you back to a tire shop and replace.
