Door code keypad sticker
Crystal
AZ NM
Ford Bronco
Does anyone know where the sticker with the original keypad door code is located?
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
Check in the space behind the drop down panel under the steering wheel. Mine was there.
Ford Bronco Door code keypad sticker IMG_2727
Eaglecountry
2025 Bronco Big Bend, 2014 Mazda CX-5 2.5L
Agree, should be covering the interior fuse box under the steering column. It’s a little business card thing with blue text on it and a big code.
Ducati1098
The card in the fuse box is not for the keypad.
The keypad number will not be located anywhere in the vehicle.
If you lost the original card and don’t have the number, only a dealership can retrieve it.
‘21OBX
90Bronco19
2022 bronco outer banks
Did the code work tho? Both of our broncos had them there even when they didn’t have a keypad from factory.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Quoting for emphasis. The internal fuse box SucuriCode card is not for the keypad.
RagnarKon
Ford Bronco, Escape, Focus
I'll take your quote and raise with another quote for extra emphasis. :giggle:
I get the question all the time on my keypad video. The card by the fuse box would be the correct code if the Bronco had a hardwired keypad. The Bronco does not have a hardwired keypad, it's a battery-operated wireless device stuck on the door.
There should be another card somewhere in the vehicle—typically in the glove box.
BroncoDude
Sammamish, WA
Great question - I have never used the keypad so honestly don’t know.
TrailDamage
Does this method not work? I haven't tried it personally. May ne no good for the wireless ones in the bronco.
https://www.ford.com/support/how-to...7Ci7E09rWRWUa8mREXXFWIl550hzFarSvhgzSqM9Gtt-F
It would not. The wireless keypad is more of a "key" as far as how the vehicle sees it. The code that would display would match what is on the BCM (fuse box) as that's the closed circuit code. It does surprise me Ford hasn't offered a hard wired option. I feel like maybe that will be coming given the fact they finally do a pillar mounted pad that's wireless still. Wouldn't take much to just run the needed wires to that area and get rid of this nonsense once and for all.
Ducati1098
Squatch
Not with the accessory style stick on keypad.
That will only work for the integrated or hardwired variation.
Quoting all of these to emphasize how pathetic Ford's decision to not give Broncos a hardwired Securicode keypad was and equally as flaccid is the roving excuse that the windows are frameless or that the doors come off when they designed the side mirrors to stay on and they're already asymmetrical.
totaljustice
Kevin
Middle Sackvegas, NS
I thought that card was for when you lost a key fob to make it easier for a dealer to replace the fob. Like what used to come with the physical key you got with new vehicles.
Noconer
Republic of Texas
22 Bronco WT
I bought a used F350 several years ago and needed the code. I researched and learned that there was a sticker on the factory radio, hidden behind the dash I removed a panel and reached my phone back there for a photo. It worked. Maybe something similar for Bronco? I think it was a 2015 F350.
