Door code keypad sticker
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
I bought a used F350 several years ago and needed the code. I researched and learned that there was a sticker on the factory radio, hidden behind the dash I removed a panel and reached my phone back there for a photo. It worked. Maybe something similar for Bronco? I think it was a 2015 F350.
Nah.
But you are correct. On older Ford vehicles it was indeed a sticker, often stuck on a module in the passenger footwell behind a trim/kick panel.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Nope becaus the bronco keypads are stick on not wired in like the rest of ford products have been since the 90’s.
Cristal_la_Pistola
Crystal
AZ NM
Ford Bronco
First of all, thank you it was located there, but the code under the steering column is different from the code on a card in the glove box.
Did the code work tho? Both of our broncos had them there even when they didn’t have a keypad from factory.
The code that worked was on the card in the glove compartment. Very strange. This is different from the instructions that came in the package with the card in the glove compartment. It states that the factory code should work, even if the code is changed to a different code, but that code that’s on the sticker under the steering column does not work at all.
‘21OBX
Ken
90Bronco19
That has been my experience too the factory code is actually the code on the Solaris card that comes with the keypad.
